I have a 1991 280E 110 engine.<br>
<br>
As a bold excersise I had it converted to run LPG on a venturi system. All was good, economy down by approx 25%, power down a little, but it made long distance runs affordable. My problems started when I had a 'blow back' one cold morning. The car was fine on LPG but would idle and start on petrol only when the engine was cold. Hot starting was a pain, and worse still, if I was running on petrol and had to stop at a junction, the engine would decelerate to the point where it just cut out. If I caught it in time or decelerated slowly then the engine would idle properly, but rapid deceleration often caught me out, leaving me to try to start with some accelerator dialed in. <br>
<br>
The vehicle has covered 160K miles and as far as I can tell the fluids etc have been serveced well enough. all is clean with no contamination in the coolant. I have checked hoses and the air filter but despite repairing some cracks in the hoses, there is no improvement. Infact I am now finding that it is a much less certain thing that it wil idle for more than 30 sec's or so before the engine gently dies down to a stop. My LPG garage has not been able to fix it and I am a bit puzzled.<br>
<br>
Any advice?<br>
<br>
Discussion Starter #2
Several things it may be. Thermastat may be stuck closed, causing the engine to run hotter than it should. There is also a screen in the fuel tank that prevents debris from entering the lines, if it is clogged, that might explain the engine shutting off. Also check to see that the electric fuel pump from the tank is working. A quick fix may be using a fuel injector cleaner that you just pour into your tank with the regular gas. Hope this helps.
