hey guys just had some rain and realised its getting into my trunk.
- i just had the front and rear windscreen seals replaced
- sunroof was covered with a tarp, so cant be that?
- on the right side of the car (when facing the trunk) the i traced the water up to where you fill up fuel. there is a little hole below the fuel cap where water just goes through and into the trunk? whats ment to be there to prevent this?
- on the left side i traced the leak up and its dripping through the left rear speaker hole.
any help appreciated
Thanks!
Indeed the tube should go from the hole next to the filler cap all that down through the inside of the trunk and then down through the floor so that it comes out just behind the rear axle - next to the little bracket that hold the flexible rear brake line to the solid part of the brake line. If that isn't connected then spilt fuel and rain water will drain into the trunk.
Take a look at the rubber gasket that goes around the filler tube on the fuel tank too.
