Hi everyone
I can't figure out what psi to put on my tires..
Just wondering if anyone has experience with this tire size? They are Nitto 420s 's
It says max load 2337 lbs at 44 psi.
Thanks,
1999 ML320
check your fuel cap.. btw how are those nittos? have been thinking of some..
I did check the fuel cap but I don't think this size is the original size? cuz thats not what was on my ML when I bought it (although I did buy it used), so I don't know if its correct.
The nittos are good, grips well. It doesnt rain real often in LA but when it does these tires really help
1999 ML320
which nittos do you have? i think if it says 44 max you should be good at around 35.. 44psi is when the car is loaded. but like i said you should be fine with 35.
