1981 240D
240D Update. Fuel Level Sender Unit Question
Well I finally got around to working on the car since my final exams are over.
I replaced the shifter bushings and the speedometer cable and now the car goes into park and I know how fast I am going. :)
I tried to replace the transmission mount but never got it done.
I was told that the reason the car shakes in reverse is because of the transmission mount. I'm going to let the auto shop take care of the mount when I find another reason to take it in.
Looking under the car, it appears that someone took took it offroad like a 4x4, ran over a few logs and then let it sit in some water.
The brake lines under the drivers side are a little bent but not kinked, the floor boards have definitely hit something and when I removed the bracket to get to the mount the entire things was caked with mud and sand.
I do have two questions for you guys:
1) Is there a way to clean/repair the fuel level sending unit without having to pop down $200 on a new one?
2)The car shakes pretty violently when I start it up but smooths out while driving. I am assuming it's the engine mounts. Does this sound correct?
Thanks,
Paul
1979 280CE
1. yes, remove it and clean all the wires off with brake cleaner or something.
2. Thats probably the cause.
1981 240D
I got the sending unit out and removed the inner tube but the three wires are not connected to anything except the top of the unit. Does anyone have a diagram or explanation of where to attach the three wire (on the float, on the base, etc)
1979 280CE
The 3 wires should be attached to the base of the unit. Try to resolder them.
1981 240D
Ok, looks like the copper wire goes to the bent arm on the base and the identical wires go to the tabs on the bottom.
If I am looking at it properly, the two identical wires simply short when the floater reaches the bottom.
I will round up some wire and fire up the iron...
1979 280CE
Yes, just pull the loose wires straight down to the bottom and thats were they connect.
1981 240D
Ok, I made a slight bend in the copper connector on the bottom and reattached the copper wire to it.
I added extensions to the two silver colored wires but ran into a problem on the bottom connector.
Each wire runs into a small channel on each side. My problem is in securing them there. I can either solder them or simply wrap them around the plastic channels.
It looks like i simply wrap them around the plastic to secure them because I cam see no solder points. On the copper wire there is an obvious point to connect it to and it has old solder on it. I can find no original solder for the two silver colored wires.
Am I missing something or do I just wrap the silver wires around the plastic post or do they somehow connect to the small contacts on either side of the channel?:confused:
