i have a very tired 77 240 4 speed, can a 115 engine be installed into a 123 body?
maybe re-locate the oil filter to the fire wall or fender but will the mounts bolt up?
i have a york a/c compressor on the 123 as does the 115 240
not a lot of used 240 engines out there:eek:
just a thought
:confused:
· Administratoris Emeritus
2024 SL770
Sure it can. You'll have to fuss and fidget a little, but nothing too serious.
1977 230, 1990 300E 2.6
My '77 123 has the 115 engine from the factory. Single, side draft Stromberg carb. The oil filter should not be a problem. Mine mounts to a housing bolted onto the lower-left front side of the engine - cartridge type. A Mercedes mech I know said the 115 and 240 engines used the same lower end. Don't know if that is correct but if it is, your job should be easier because of it.
'77 6.9, 74 240D, 96 Ram 5.9L Cummins
I can forsee a problem with the IP shutoff. The W115's have a manual cable fuel shutoff and that would need to be migrated since the car isn't wired with the pull knob for that.
