W203 C 220cdi T model
Hi guys!
I've got dead battery after a night. The symptoms are :
1. After entering the car i noticed that the fog lights lamp is switched on, but my lights switch was set to 0 = off.
2. When i tried to switch the engine on the dashboard lights started to dim down and no turn from the engine= obviously dead battery= 11.4 volts
3.When i switch the fog lights on their lamp lights more brightly, but when everything is switched off the fog lights lamp still lights but less than normal bright???
4. I changed the battery, switched the engine on and i have still that silly lamp on and even that i have ESP Unavailable.
5. When the engine is off there's electrical leak between 0.1 and 0.8 mA- too high,
Can someone help me with some advices to solve that problem?!
Discussion Starter #2 (Edited)
New facts about the leak:
1.The leak is raising and decreasing between 1 A and 0.0 A repeatedly in a period of 1 minute- it stays for 20 seconds at 0.8 and 1 A then decreses till 0.25 A and then 0.1 A and disappeares for 10 seconds.
2.All the fuses are checked, but number 64 is changing the leak by 0.2 A???
3. The fog lights lamp is OK now, but the ESP stays U/A
