want a gps unit for my 01 clk430 convertible. original factory gps unit or aftermarket gps/dvd is fine. would like to keep my bose system working in the car. is there a wire harness that allows that?
Yes there is a Harness From Crutchfield.
It's listed as a VW wire harness.
It has two plug harness's in one plug.
Only one wire has to be re wired..
Other than that. It's a simple install.
Even for a novice DIY.
Make sure you buy the radio removal tool..
And if your new radio has steering.wheel controls. You will want to look into the Pac steering wheel control module.
Most cases. You need to separate modules, to use the steering.wheel controls.
