2015 Mercedes C Class Road Tested Bilstein Lowering Coilovers at CARiD
7929 Views 1 Reply 2 Participants Last post by  Pkaia524
4
It doesn't really matters why you want to drop your Mercedes for a couple of inches, is it just for looks, to get noticeable handling improvement, or if you simply want to eliminate the wheel gap when installing aftermarket wheels. Of course, the reasons may vary, yet once you have our Bilstein Front and Rear Lowering Coilovers installed, we bet you will realize that this upgrade is well-worth the money and time spent on the installation. This road-tested kit will give you a perfectly tuned suspension, for better handling and cornering. Each telescopic B16 Series Coilover features BILSTEIN monotube technology and is manufactured from highly durable materials for longer life and impressive stability. Plus, each set comes coated using Triple-C-Technology for long-lasting corrosion resistance.
Click on the pictures to find more information on this Kit at CARiD, that's already available for pre-order!
Bilstein® - B16 Series PSS10 Front and Rear Lowering Coilovers
Notes:
* Listed as a perfect fit for: 2015 Mercedes C Class C300 Base Model;
* 4 per Pack;
* Front Axle Load up to 1125 kg, Rear Axle Load up to 1270 kg;
* Finish: Blue (Springs), Zinc Plated (Front Dampers), Yellow (Rear Dampers).
Feel free to contact me if you need a price quote or any additional questions appear.
I just purchased a 2015 C300 4Matic sedan. Will the H&R sport springs lower the car, but not to the point of the aggressive stance seen in the Bilstein photo above?
Also, I want to decrease body roll and increase grip in the rear tires when In the corners. Is there an aftermarket sway bar kit for this car?
