Hello, all
I've reached my limit of troubleshooting based on the information that I could find in these newsgroups and am hoping someone can help.
Several weeks ago, I jumped into the car (2015 E400 Convertible, LHD), put the top down and drove a mile down the street, parked the car and the top wouldn't go back up.
The windows functioned but nothing from the top--no whining or whirring or anything.
So, I drove back home and parked it in the garage and began prodding. Hooked up the OBD tester thing that I have but no codes. After a while, I was over it and went back inside the house.
A couple of hours later (maybe it was the next day) I went out and tried again and it went right up. No issues.
Over the next week or so (absolutely not trusting it) I was careful about when I put the top up or down. A couple of times, it failed but then would work again after an hour. Sometimes it failed to go up. Sometimes failed to go down. In all cases, the windows, headrests and wind deflector did what they were supposed to do but nothing else. Finally, it stopped working altogether.
I was finally able to get some codes from it (Foxwell 510 Elite, I believe) after it fully stopped working.
ID, Status, Description
B255F24, Stored&Current, "The limit switch 'Soft top compartment lid IN CATCH POSITION' has a malfunction. No signal change. Voltage level is too high."
B25452A, Stored&Current, "The limit switch 'Soft top compartment lid LOCKED' has a malfunction. There is no signal change."
The first issue that I have is that those codes (B255F24, B25452A) can't be found anywhere that I have access to. They don't seem to be valid Mercedes codes and there is no lookup available from Foxwell.
By doing a ton of research on this forum, it SEEMS like the IN CATCH POSITION is S84/22 and LOCKED is S84/23 (or vice-versa... I tested them and replaced one and they are the same switch). I assumed that because both error codes refer to 'lid' not 'bow' or 'roof'... The terminology is all over the place but I assume 'lid' is the same as 'cover' and not 'top' or 'roof'.
Both of the relevant fuses that I could find (61 and 62, iirc) are fine. I can't find a relay anywhere.
Given that the pump does nothing, I would assume it's either the controller not giving the signal or that there is a fuse or relay somewhere that is bad... Rolling in the fault codes, and given that both of those limit switches tested fine, I assumed it was the N22/6... and replaced it with a reman unit from Mercedes directly... Same story. Clearing those two codes on the Foxwell and rescanning for codes immediately gives me those two codes again.
If I sit in the car (or use the key from the outside) and attempt to put he top down, all of the windows go down, the back seat headrests go down (if they happened to be up) and then nothing happens. No unlatching of the cover, no unlatching of the top at the windshield and no noise from the pump that I can hear.
So, long story longer, N22/6 is replaced and it's unlikely that a freshly remanufactured unit (in my opinion) would be defective in exactly the same way my original one is (assuming it is). The limit switches that I THOUGHT were indicated by the fault codes test s/c and o/c as they should. Fuses 61 and 62 are fine. Can't find a relay anywhere.
The problem was initially intermittent. Maybe someone with intimiate knowledge of the 'top opening steps' could say what the issues is just by where the process stops.
I'm beginning to wonder if the 'lid' in the fault code is a mistranslation and actually refers to the TOP/ROOF in catch position and locked:
...switches
S84/11 (Left soft top "locked" limit switch)
S84/18 (Soft top limit switch in catch position)
... instead of (as I assumed)
S84/22 (Soft top compartment cover in catch position limit switch)
S84/23 (Soft top compartment cover "locked" limit switch)
(And I don't know whether S84/11 and S84/18 being routed to the CANbus have anything to do with how/whether they showed up on my Foxwell tester...)
It's got be either that, a second bad control unit, some other relay/fuse or, I guess, aliens or something. Maybe a ghost.
Anyone make it far enough into this post to have an idea?!
Thanks!
Marshall
N22/6 - A207-900-65-00-04 (part I received 207-900-65-00-80, but marked as -04)
S84/22 and S84/23 - A207-820-79-10
I post these because it took me forever to find anyplace that cross-referenced these "S84" identifiers with Mercedes part numbers, so maybe this helps someone.
...switches
Thanks!
Marshall
