Hello,
My mercedes has a leak around the gas tank. The hose that goes from evap canister on passenger side of the car that goes to the top of the gas tank is wet and has sapy build up on it. The tank strap is also wet but not dripping wet. How can i safely drop the tank to see where the hose or connector is cracked for replacement?
Thanks for any assistance.
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
This might be covered under warranty. The emissions warranty is for 8 years, 80K miles These are the items covered related to the fuel tank:
EVAP Canister, EVAP Canister Purge Valve, Fuel Fill Neck, Fuel Filler Cap, Fuel Tank (with Integrated Vent Valve and/or Fill Neck), Fuel Tank Pressure Sensor, Fuel Tank Vent Valve
