1 - 8 of 8 Posts
i have got an R231 2013 SL63 with 40,000km
When i bought the SL there is the ABC malfunction warning but it comes on and off.
In the center display screen showing the ABC and G force, during driving i can see the ABC indicator beside the wheel will have the red column showing ABC is active by going up and down
I was ask by the Dealer that the ABC pump and ECU need tobe replaced in which i did.
After all the expensive repairs, the ABC screen in the center console whereby the ABC indicator is not moving even during driving.
But when i engaged the vehicle lift, the ABC indicator shows the car is lifting as the red column indictor will move.
Went back to the dealer and told me that this is normal that the ABC indicator will not move during driving.
Can someome give some advice is this normal?
Maybe can email me some video of the screen during driving as i cant find in youtube so i can argue with the dealer.
13 SL63
when you are on high level at a stop, then drive, the car lowers to what ever height it wants, it doesnt matter what button you push, it drives at what height it wants. when you come to slow speed it goes back on hi level.
When you are driving, It does show on the graph what height it is at, but you cant do anything about it
I do understand that when you drive the car will adjust itself to the height depending on the speed.
I wanted to know during driving does the ABC display screen show the red column bouncing up and down?
E.g. When going on a high speed corner the indicator on the display screen should show the red column that the pressure is on which side.
Attached image what I mean by display screen
Discussion Starter · #5 ·
as far as I have noticed, it would not go that low unless you were at a stop, it wouldnt look like that while moving at all
Hi OKB,
That is what i thought, but the dealer told me that is normal.
I tried to find more info/video/review online but not sucessful as not much video on this indicator
Anyone who can share some video of the ABC indicator when their SL is on the move will be extremely helpful so i have some ground to argue with the dealer
Sent from my SM-T825Y using Tapatalk
13 SL63
at stop it is very low line, then when driving it goes up to a little above the o or mid line. when you slow or stop and push raise, it goes up near top line. Then when you drive off it goes to the middle again.
Thne g force markers light as you go into cornering, it shows the pressure against the side or wheel you are cornering against
1 - 8 of 8 Posts
