1 - 15 of 15 Posts
I guess they had to increase the size of the grille to handle all the heat generated by two turbos, but I don't think the 2012 looks as good as the current model.
Official (lengthy) press release
Affalterbach – The new Mercedes-Benz ML 63 AMG stands for efficiency and performance, exclusivity and a superlative driving experience. Running on 11.8 litres of fuel per 100 kilometres (NEDC combined, 276 g CO2/km), the high-performance SUV undercuts its predecessor by 4.7 litres, or 28 percent. The basis for low fuel consumption and top-class performance is provided by the AMG 5.5-litre V8 biturbo engine with a maximum power output of 386 kW (525 hp) and maximum torque of 700 Newton metres, representing an increase of 11 kW (15 hp) and 70 Newton metres. The optionally available AMG Performance package boosts the V8 engine's power output to 410 kW (557 hp) and its maximum torque to 760 Newton metres. The newly developed ACTIVE CURVE SYSTEM for active roll stabilisation, the AMG-specific design and the broad scope of standard equipment and appointments provide for a highly attractive overall package.
The new ML 63 AMG comes with a fascinating technology package: the AMG 5.5-litre V8 biturbo engine features spray-guided direct petrol injection with piezo injectors, ECO start/stop system, an all-aluminium crankcase, four valves per cylinder with camshaft adjustment, air-water charge air cooling and generator management, for example. With a displacement of 5461 cc, the eight-cylinder engine generates a maximum power output of 386 kW (525 hp) and 700 Newton metres of torque. In conjunction with the AMG Performance package these values rise to 410 kW (557 hp) and 760 Newton metres. This difference in power and torque results from an increase in the maximum charge pressure from 1.0 to 1.3 bar. Both variants of the ML 63 AMG enable sports-car performance: acceleration from zero to 100 km/h takes 4.8 seconds and 4.7 seconds respectively, while the top speed stands at 250 km/h (electronically limited). With or without AMG Performance package, the NEDC fuel consumption level of 11.8 litres per 100 kilometres (276 g CO2/km) remains the same. The AMG Performance package further includes an engine cover in high-quality real carbon, callipers in red painted finish and the AMG Performance steering wheel in nappa leather/DINAMICA.
The key data at a glance:
Displacement: 5461 cc
Bore x stroke: 98.0 x 90.5 mm
Compression ratio: 10.0 : 1
Output: 386 kW (525 hp) at 5250 rpm; 410 kW (557 hp) at 5750/rpm*
Max torque: 700 Nm at 1750-5000 rpm; 760 Nm at 2000-5000 rpm*
Engine weight (dry): 204 kg
Fuel consumption, NEDC combined: 11.8 l/100 km
CO2 emissions: 276 g/km
Acceleration 0-100 km/h: 4.8 s; 4.7 s*
Top speed: 250 km/h**
* with AMG Performance package; ** electronically limited.
Efficient and variable: AMG SPEEDSHIFT PLUS 7G-TRONIC
Power transmission to all four permanently driven wheels is performed by the AMG SPEEDSHIFT PLUS 7G-TRONIC system. Featuring three driving programmes and an automatic double-declutching function for downshifting, this seven-speed automatic transmission offers a fascinatingly broad scope of variability. In "Controlled Efficiency" mode (C) the ECO start/stop function is active, shutting down the eight-cylinder engine when the vehicle is stationary. "C" also stands for a gentle accelerator and transmission characteristic with comfortable and early gear changes; start-up generally takes place in second gear here. A green "ECO" symbol in the AMG instrument cluster indicates to the driver that the ECO start/stop function is active.
In the Sport (S) and Manual (M) driving programmes the ECO start/stop function is inactive and the engine-transmission combination displays far greater agility. A brief and exactly defined retardation of ignition and injection during upshifting at full load additionally provides for shorter shift times here.
Enhanced efficiency and driving dynamics
As efficiency-enhancing measures, the AMG SPEEDSHIFT PLUS 7G-TRONIC automatic transmission incorporates a new fuel economy converter with centrifugal pendulum, bearings designed for reduced friction loss and a transmission-oil thermal management system. Friction loss-minimised axle gears, electronic steering, an optimised belt drive, demand-responsive control of all ancillary units and pumps and an intelligent lightweight design all help to further reduce fuel consumption. The new ML 63 AMG is 40 kilograms lighter than its predecessor – despite the increase in power and the more comprehensive range of standard equipment.
As on the previous model, Mercedes-AMG deploys a specially designed transfer case for the 4MATIC permanent all-wheel drive which distributes the engine power at a ratio of 40 : 60 to the front and rear axle in the interests of high driving dynamics. Furthermore, the AMG sports suspension with AIRMATIC package, air suspension, independent damper struts, automatic level control and Adaptive Damping System (ADS) features for the first time in combination with the ACTIVE CURVE SYSTEM for active roll stabilisation. This system, which comes as standard, employs active anti-roll bars on the front and rear axles to compensate the body's roll angles during cornering. In addition to enhanced agility and driving enjoyment, the system also improves driving stability for added safety at higher speeds in particular.
Roll stabilisation, damping and suspension adapt instantaneously to the prevailing driving situation, offering both optimum ride comfort and maximum stability. The driver is able to choose at the push of a button between the three driving modes "Comfort", "Sport" and "Manual". The fully load-bearing air suspension system is speed-sensitive, lowering the body when higher speeds apply in order to minimise drag while increasing driving stability.
The AMG-specific elastokinematics at the front axle and the more robustly designed rear axle stabiliser bar are responsible for improved steering precision. The enhanced drive train stands for optimum power transmission and hallmark Mercedes reliability. The 4ETS electronic traction control system which features as standard provides for optimised grip when low friction coefficients apply.
AMG speed-sensitive sports steering, AMG high-performance braking system
Electromechanical AMG speed-sensitive sports steering features vehicle speed-dependent power assistance and helps to save fuel, as the steering assist function only requires energy when the driver actually moves the steering wheel. The ML 63 AMG comes as standard with 5-spoke light-alloy wheels in format 9 x 20, painted titanium grey and with a high-sheen finish, fitted with tyres in size 265/45 R 20. Tyres in size 295/35 R 21 on AMG light-alloy wheels in size 10 x 21 are optionally available. The AMG high-performance braking system provides for the shortest possible braking distances and high fade resistance, featuring ventilated and perforated brake discs all-round in size 390 x 36 (front) and 345 x 26 millimetres (rear).
Specific AMG styling with trim in matt silver chrome
The design of the new MG 63 AMG exudes self-confidence, athleticism and power. The AMG styling dominates the front view: under the radiator grille with louvres in high-gloss paint finish and the large Mercedes star is a large cooling air intake on which the number plate is positioned. Together with the two outer air intakes, the central radiator grille provides for an effective flow of air to the water, engine oil, charge air and transmission oil coolers. Fitted at the bottom of the AMG front apron is a trim strip in matt silver chrome, which lends the front a wider appearance while harmonising with the surrounds of the daytime driving lights in the side cooling air intakes. The headlamps cut a particularly high-quality and exclusive figure in combination with the optional Intelligent Light System (ILS). The AMG front apron is integrated with the distinctive front fenders, which are 10 millimetres wider on either side in order to accommodate the large AMG light-alloy wheels in elegant fashion. "V8 BITURBO" logos identify the vehicle as the top AMG model in the M-Class. Dynamically profiled AMG side sill panels establish a visual link between the front and rear of the vehicle.
Another eye-catching feature is the AMG rear apron highlighting the black air outlet openings. The outlet openings emphasise the vehicle's width similarly to the trim strip in matt silver chrome, which cites the design of the front apron and frames the AMG sports exhaust system. In contrast to the other M-Class variants, the ML 63 AMG features two sets of chrome twin tailpipes. Typical of an AMG is the distinctive full eight-cylinder sound.
High-quality, sporty interior
A sporty character and premium quality define the interior of the high-performance SUV from AMG. This is embodied in the electrically adjustable AMG sports seats offering pronounced lateral support as well as the four-spoke AMG Performance steering wheel, which ensures optimum control of the vehicle with perforated leather in the grip area, aluminium shift paddles and a flattened bottom rim. Aluminium trim elements and the piano-lacquer retractable cover in the centre console highlight the interior's special dynamic and exclusive flair. The standard leather upholstery includes contrasting double topstitching and AMG badges in the backrests of the front seats and the outer rear seats. Dashboard, armrests and door panelling in AMG-specific design are finished in ARTICO man-made leather with double topstitching.
The distinctively designed instrument cluster with colour TFT monitor, AMG welcome logo and AMG main menu is exclusive to the ML 63 AMG.
Other standard equipment includes:
■ AMG door sills in stainless steel
■ AMG sports pedals in brushed stainless steel with rubber studs
■ Audio 20 CD radio with Bluetooth and USB interface
■ Tyre pressure monitoring system
■ Electric sliding glass roof
■ Heated seats for driver and front passenger
Exclusive optional extras are also available from the AMG Performance Studio:
■ AMG floor mats
■ AMG light-alloy wheels (10 x 21) in 5-spoke design, painted in titanium grey with a high-sheen finish, fitted with tyres in size 295/35 R 21
■ AMG Performance steering wheel in nappa leather/DINAMICA
■ AMG Performance package with increase in power of 24 kW (32 hp) and 60 Newton metres more torque, AMG engine cover in high-quality real carbon, AMG Performance steering wheel in nappa leather/DINAMICA, callipers in red painted finish
Tailor-made individuality with designo
The designo range enables ML 63 AMG customers to realise their very own personal style. The designo Exclusive package includes nappa leather upholstery on the AMG sports seats featuring an unusual diamond pattern. The leather upholstery is available in designo marron, designo porcelain and designo black. The scope of features also includes AMG badges in the backrests of the front seats and the outer rear seats as well as velour floor mats with designo metal badges and black designo leather edging. A designo roof lining in DINAMICA black rounds off the designo Exclusive package. ...
Additional optional items:
■ Trailer coupling with electric unlocking
■ Becker® MAP PILOT
■ Electrically operated EASY PACK tailgate
■ Rear Seat Entertainment System
■ harman/kardon® Logic 7® surround sound system
■ Wood/leather steering wheel in nappa leather
■ THERMOTRONIC luxury automatic climate control
■ Light package including Intelligent Light System
■ Media interface
■ Memory package
■ COMAND Online multimedia system
■ Electrical panoramic sliding glass sunroof
■ Aluminium-look running boards with rubber studs
■ TV tuner
■ Wood trims
Safety of the very highest calibre
In line with the Mercedes-Benz brand philosophy, the new ML 63 AMG represents the embodiment of the Mercedes-Benz holistic safety concept of Real Life Safety, which is derived primarily from what happens in a real accident situation. The extremely robust occupant compartment, together with the front and rear deformation zones, forms an effective basis for the occupant protection system. Up to nine airbags, activated on demand in accordance with the accident type and accident severity, can reduce the loads exerted on the occupants. In addition to active safety systems such as the standard-fit Brake Assist (BAS) or the optional BAS PLUS, which can help to prevent an accident or reduce the severity of an accident, the new M-Class features further enhanced passive-safety measures to help protect pedestrians.
Both active safety and driver-fitness safety are improved by assistance systems that will already be familiar, primarily from the S- and E-Class. The standard equipment package includes the drowsiness detection system ATTENTION ASSIST, the anticipatory safety system PRE-SAFE® and a tyre pressure loss warning system, as well as adaptive brake lights and the ESP® electronic stability programme. Active assistance systems such as Active Lane Keeping Assist and Active Blind Spot Assist are available as additional equipment options.
Visionary: AMG as the inventor of the high-performance SUV
The new ML 63 AMG from Mercedes-AMG represents the third generation of the high-performance sport utility vehicle. The company from Affalterbach was the first to identify the potential of powerful and exclusive off-road vehicles and is recognised as the founder of the high-performance SUV segment. It all began in 1999 with the ML 55 AMG: with a power output of 255 kW (347 hp), the top-of-the-range M-Class model powered by an AMG 5.5-litre V8 engine achieved a level of performance previously undreamt-of in this class, with acceleration from 0 to 100 km/h in just 6.8 seconds and a top speed of 235 km/h. The unusual combination of high-calibre drive, excellent off-road capabilities, outstanding ride comfort, unparalleled safety and a spacious interior delighted AMG customers throughout the world. Over 11,000 ML 55 AMGs were sold between 1999 and 2003.
The follow-up ML 63 AMG which was presented at the Frankfurt International Motor Show in September 2005 continued the success story that had begun with the ML 55 AMG. With its AMG 6.3-litre V8 engine generating an output of 375 kW (510 PS) and 630 Newton metres of torque, it again set the benchmark in its segment. The performance of the ML 63 AMG was in the sports-car league: the top-of-the-range AMG model accelerated from 0 to 100 km/h in 5.0 seconds and had a top speed of 250 km/h (electronically limited).
Over 13,000 were sold in total between 2006 and 2011.
In all, AMG's sales figures for its high-performance SUVs total over 24,000 to date.
The new Mercedes-Benz ML 63 AMG will be launched in April 2012.
Overview of prices (incl. 19% VAT):
ML 63 AMG: € 108,885
AMG Performance package: € 7021
Looks are personal, but I disagree. It's aggressive without being over-the-top. I like how the front and rear have a common theme of opening shapes. Wheels are different without being foreign to AMG. Added flares on the W164 version seem like (and were) an afterthought to me; the integrated 10mm wider fenders on this model are cleaner.
Apart from the looks (which seem to me like change just for the sake of change, a trap the American auto industry got into 20 years ago), Mercedes also seem to be playing catch-up. They are chasing a couple of years behind Audi in the over-use of silly LED daytime running lights and they are chasing a couple of years behind BMW in the engine and transmission technology. Maybe that's why their market share and share price have both been dropping. (BMW recently passed Mercedes in terms of overall market valuation, for the first time ever.)
I love my ML, but the only thing that really sets it apart from the competiton is the Airmatic suspension. Mercedes is going to have to do a lot better if they want me to trade up when the time comes.
Yeah, the LEDs were cool when they were new, but now a little overused - still better than incandescent DRLs, though. I think Mercedes has almost caught up in engine technology. The new 6s are very good, just no FI 6 gas. And, the hybrid is certainly not cutting edge.
BMW is investing heavily in carbon fiber production for future vehicles, and Audi & Jaguar in aluminum. I don't see Mercedes focusing on weight reduction, which is probably the most important future need.
The topic was the ML63 not hybrid or V6's. The new engine and the dual clutch transmission are pretty top-line. I've driven the new E63 and the CLS63 with this combination and the performance is outstanding. I am looking forward to driving and perhaps trading my ML63 for a new one.
Trannys
A slight correction, the ML63's (as also used in other AMG models) transmission is a single clutch automatic, not dual clutch. The MCT transmission is essentially the 7G-Tronic automatic transmission without a torque converter. Instead of a torque converter, it uses a compact wet startup clutch to launch the car from a stop, and also supports computer-controlled double declutching. The MCT (Multi-Clutch Technology) acronym refers to a planetary (automatic) transmission’s multiple clutches and bands for each gear.
ML63 Option Pricing
Here is pricing so far. No base price, but probably same as 2011 (~$93k).
Autoweek article - new pics
2012 Mercedes-Benz ML63 AMG: Drive review
By: Barry Winfield on 1/13/2012
What is it?
AMG’s upgrade of the third-generation Mercedes ML SUV retains the ML63 nomenclature, even though it switches from the 6.3-liter V8 to a twin-turbo, direct-injection 5.5-liter V8. In this guise the car produces 518 hp at 5,250 rpm and 560 lb-ft of torque from 1,750 rpm to 5,000 rpm.
The company also offers a performance package for the ML63, bumping turbo boost pressure from 14.5 psi to 18.8 psi to increase engine output to 550 hp and 560 lb-ft of torque. The package also increases top speed from the usual electronically limited 155 mph to a similarly limited 174 mph. An influence of the Porsche Cayenne, maybe?
As is usual with Mercedes products, there is a battery of electronic driver’s aids, including ABS, ESP, active parking assist, attention assist, blind-spot assist and lane-keeping assist. Distinct from those are optional active versions of blind-spot and lane-keeping assist, where the stability-control system applies brakes selectively to correct the driver’s course.
The torque split on the ML63’s 4Matic all-wheel-drive system is biased toward the rear, at a 40/60 ratio, and the chassis specifications include air springs, adaptive damping shocks and what the company calls the active curve system (basically variable roll stiffness produced in response to driver and vehicle inputs) provided by actuators at the car’s antiroll bars.
Although comprehensively equipped as standard, the ML63 offers a list of options that includes active cruise control, rear-seat entertainment, B&O audio and more.
What is it like to drive?
As we’ve come to expect from AMG vehicles, the ML63 belies its 5,000-pound mass both in the way it accelerates and the way it handles. With max torque from way down on the tachometer, the car steps off with serious intent and runs to 60 mph in a claimed 4.7 seconds. It never feels anything but decidedly muscular, and the constant staccato grumble from the exhaust underscores the engine’s potential.
But the ML63 also boasts much improved fuel economy (33 percent better, according to company claims) and can be driven at moderate speeds with excellent accompanying refinement and comfort. Still, with AMG ride control composed of air springs, adaptive-damping shocks and variable roll-stiffness actuators, the ML63 adjusts to fast driving in a surprising fashion.
Big 21-inch wheels mount sporty Michelin summer tires, and the grip levels are high. Add the carefully composed chassis, and you have a big SUV that cuts swaths through canyon country in a way that will shock its occupants. An electromechanical rack-and-pinion steering mechanism directs the car with accuracy and a fair amount of feel, and one is soon marveling at its ability to pick and hold precise cornering lines.
The brake pedal has a fairly long travel, but this helps modulate the amount of pressure going to the big rotors in a way that makes driving in traffic very intuitive. While we’d prefer a tad less movement in higher-intensity applications, braking performance was always strong and dependable.
We think the interior design is a big improvement on the previous car, especially when tricked out with the unique AMG touches, and there is more than enough technology included to help the driver find his way without backing or crashing into anything. You can vary chassis programs among comfort, sport and sport-plus, or select from economy, sport and manual at the transmission, depending on your needs.
When in economy mode, the engine will shut off when the ute stops, then restart when you remove your foot from the brake. The ML63 easily embraces the various roles described for it by the technology. It will troll the urban landscape with a quiet and calm demeanor or storm a mountain road with every muscle flexed and be equally convincing in either role.
Do I want it?
The idea of a high-riding, all-wheel drive, go-anywhere SUV with a dual personality only appeals to fans of the genre. The rest of us equate performance with sports cars or sport sedans. Yet the ML63 is a convincing shape shifter here, able to handle pretty much all of the tasks typically confronting a vehicle in a thoroughly convincing manner.
Much of its versatility is as a result of expensive technologies expertly applied by talented engineers. So it’s not cheap. The price is not yet fixed in the United States, but Mercedes personnel are guessing $80,000. But wait, before you protest, consider the European price of about 109,000 euros, which is about $138,000. That’s nearly a $60,000 discount, fellow Americans. So rejoice.
On Sale: April
Base Price: $80,000 (est)
Drivetrain: 5.5-liter, 525-hp, 516-lb-ft twin-turbocharged V8; AWD, seven-speed automatic
Curb Weight: 4,900 lb (est)
0-60 MPH: 4.7 sec (mfr)
Fuel Economy: 16 mpg (est)
The exterior doesn't feel right. The front head lamps were taken from Volvo, the rear tail lights are too large and plain. The interior looks identical to Cherokee we rented in Montana a few weeks ago. Boring... :(
The exterior feel right,so does the interior, bad sexy machine.
Autoweek 2-6-12 ML63 article
1 - 15 of 15 Posts
