E-Class, SLK
Strange, the transmission filter on my 2011 E350 does not stay straight/level when installed (the rear end dropping/pulling down lower). I noticed that the original filter was also installed the same way. I’m sure I installed the filter correctly since it requires some force to remove it. I wonder if yours are the same or just mine. My SLK (with 722.6 trans) does not have that issue.
13 GLK350, 02 325, 94 sonoma, 12 RAM, 01 WS6
you have a .9 trans in the E. there is nothing that holds the rear of the filter up like you .6 trans does. the dimples in the pan will keep the filter from falling out. DO NOT worry about it. I questioned this years ago when I started with MB. its normal.
