Well after replacing just about every front suspension part including front and rear lower control arms I still had a hideous squeak over minor bumps that drove me crazy. I pulled the lower engine cover and found what looked like oil on the drivers side. After a bunch of research I determined the left motor mount had collapsed and leaked fluid out. I also looked into changing both motor mounts but I am a little stumped on how to get access to the bolts and even the mounts to get them out.
I watched a few videos specifically for the 4matic and understand you have to remove both CV joints and disconnect the upper suspension U mount so the engine can be lifted high enough to get the new mounts in. I'm fine doing that since I had to pop out both cv joint ends to install the front LCA.
On my vehicle it still has both motor mount heat shields blocking access to the top bolt. I found there is a special tool 16mm that I need to buy to remove the top bolts. I am fine with that as well.
My issue is that I cannot even get my hands close enough to the mounts from the top to get the mounts out or the new ones in. Then I'm not even sure how to get the bolts back in. I'm ready to just purchase a decent set of mounts and have my local shop do this. Especially since it is 19 degrees here and my garage is full.
If anyone has don't this job let me know how you did it bc I'd like to get this done asap.
Thanks.
Ted
Thanks.
Ted
