1 - 14 of 14 Posts
Hi everyone, I get this grinding noise as I accelerate. It sounds like the tranny gears are grinding. Any clues as to where I should start?
1999 C280, 2000 C280, 2000 C230K,2011 C300
What's your mileage?
You have isolated the noise to only when accelerating in gear?
So no noise when revving car in neutral?
Yes, the engine sounds just fine. Only when accdllarating or going over 40mph. I believe the torque converter.might be the issue here.
My speakers are pretty crap but that sounds more like wheel bearings to me, does the noise change as you steer left to right while driving?
Does it get worse the faster you drive, as if its a constant noise that just increases with speed?
Does it change pitch like gear changing gears the faster you go?
Generally with a wheel bearing if you drive slow its hard to detect, the faster you go the worse it gets to the point if its real bad you can feel it.
I would be jacking the car up on stands and see if the noise is there with the wheels off the ground, then check each wheel for a noise to pinpoint which one it could be.
No change in steering turns. The sounds is pretty consistently during accellarating at about 40mph and more.
Same noise, no change in intensity.
I have not noticed the tranny having any issues changing gears.
I dont believe it is a wheel bearing issue but you never know.
and no the sounds doesn't change pitch the faster I go, its a pretty consistent sounds just like the video.
Get it onto a hoist and check it, try to simulate the speed of the car with it in the air and see where its coming from
pretty hard to diagnose something when you are inside and driving, you need someone in the car while someone checks from underneath.
1999 E430; 2005 ML500
Don’t overlook motor mounts at that mileage. Engine shifting an cause the fan or something else to hit other things.
1 - 14 of 14 Posts
