2011 C300 Sport
Hello Folks my car has about 21,000 miles and service A notice came out on the dash.
I will be taking my Benz to the dealer this week for the required maintenance( I pre paid 3 services when I bought the car)
Things that need to be change as the maintenance booklet says:
Oil change
Dust Filter
Break fluid
Should I demand Coolant build change?
Are break pads included in the pre-paid maintenance?
Any suggestion to inform my advisor before taking my car to MB dealer is really appreciated.
Thank you all
Jonathan,
Check your local MB dealer and ask them about A and B services?
FYI MB service schedule every 10K alternate b/w A&B services
Example: for new car, A service when you reach 10k then B service when you reach 20K and A service again when you reach 30K and so on....
It's strange to me that your car reach 21k and the A service message come up? when the car reachs 20k B message should appear on dashboard not A! maybe I am missing something!
I don't think replace brake pads and cooling come with pre-paid maintenance. but I can be wrong check with your MB dealer when you purchase the car.
2011 C300 4Matic Sport
A-Service (every other 15,000 km / 10,000 mi)
Engine oil & filter change
Warning & indicator lamps, illumination & interior lighting
Windshield wipers & washer system, wiper blades
Reset FSS counter in instrument cluster
Horn, high beam flasher, hazard flashers, turn signals, running lights
Front & rear lamps, trunk light
Brake system & front brake pads (one wheel)
Tires - damage, condition, inflation pressure, spare tire
Engine hood catch, safety catch and hinges
Engine cooling system, antifreeze & corrosion protection
Battery fluid level, condition using Midtronics tester
B-Service (every other 15,000 km / 10,000 mi)
All A-Service items including oil & filter change
Seat belts, parking brake, horn
Cabin filter
Brake pads front & rear - lining thickness
Brake disc rotors - condition & thickness
Brake system - fluid level
Tires - measure tread depth & record in mm
Underside chafe marks, line routing, damaged components
Front axle ball joints & rubber boots
Steering components & rubber boots
Headlamp setting, wiper blades
Poly-V belt condition
Power steering
Additional Work at Specific Intervals
Every year - Sunroof - clean sliding rails and sliders
Every 2 years - Replace brake fluid, inspect suspension, paint damage
Every 4 years - Check driveshaft flex discs (80,000 km / 50,000 mi)
Every 4 years - Replace engine air filter element (80,000 km / 50,000 mi)
Every 5 years - Replace spark plugs (125,000 km / 80,000 mi)
Every 5 years - Replace fuel filter, activated charcoal filter (105,000 km / 65,000 mi)
Every 15 years - Replace coolant (250,000 km / 160,000 mi)
Cabin filter
Power steering
So basically the "A" service is an oil change, new wiper blades and a bunch of items checked. And for this a dealer gets close to $600. :eek:
