2011 C250 4Matic (C300) M272 Runs rough and sputters
Before I bring it back in to the shop I thought I’d check with all of you.
2011 C250 4Matic (Canada only, same engine as the C300)
Symptoms
Runs rough and sputters at 1600-2200 rpms, even worse up a hill.
Seems to run fine when cold, first few min.
Runs smooth while idling
Not throwing any codes or pending codes.
Replaced all the plugs, 4 Camshaft Adjusters, air filters and the intake manifold actuator (was broken)
Thinking maybe I should replace the Coils and the Fuel filter… Grasping at straws here…
Check airmass flow sensor. You can try with a cleaner . Worked great. Normally you have a code but sometimes the ecu doesn’t recognize the problem, especially when it only appears in a small range . The other is primer fuel pump pressure. It’s sitting inside the fuel tank.
Misfiring from the ignition system is always found with Dtc.
Sounds like a fuel pump issue. This symptoms can also occur if you are low on fuel and you hit the gas pedal or go up a hill.
About this Discussion
3 Participants
Vincent713
Mercedes-Benz Forum
Full Forum Listing
