21 - 27 of 27 Posts
2015 GLK350 Base
Mike, thanks for your comments . I think the difference is your stutter was one you could feel, but your engine was running smooth. Mine is shifting OK, and the car is smooth, but until warmed up it's like the engine is missing (skipping). Maybe that's typical with these, this is the first V-6 MB I have driven . My other MB is a 500+hp sl550 that doesn't miss a beat - warm or cold .
It shouldnt be that way … my partner drives an eight cylinder and I drive a six, it doesn’t and shouldn’t skip … maybe have some with a star machine check it out
2015 GLK350 Base
Update: I now have driven at least 2,000mi using Ethanol free Premium AND at each fill up adding 8oz of Marvel Mystery oil. Unless my shutter was due to cooler temperatures it now has almost vanished. Perhaps the prior owner absorbed some water in the ethanol gas that the injectors didn't like and MMO has cleaned things out. If it comes back in the fall, I'll repost, but for now: all is well.
Hi all,
My brother has a 2010 glk350 with 150k miles purchased privately around a year ago. It started having shudders and power loss after 1st gear. There was no check engine light or anything but I figured it was a transmission issue so I told him to take it to the tranny shop. They quoted him $1800 for a new torque converter. Their idea is that the lock up clutch is failing. Before emptying our wallets, I decided to try and change the fluid myself and see if the issue would go away. I changed about 6L of fluid and we noticed that the car regained power and the shudders are 80% cleared, but still there. While slowly accelerating, I notice the rpms shifting up and down like a manual transmission clutch slipping and catching. I think the new fluid is allowing more slippage so its not as rough. I fear that the car might need its torque converter replaced, but I wanted to ask if it was worth dropping the valve body and conductor plate to replace the torque converter lock up clutch solenoid. This would cost around $250 to change out properly. I have no doubt in my ability to do this project, I just want to ask if it is worth it, or to have the shop take the transmission out and replace the whole converter. Thanks in advance for your advice and thoughts
It is imperative to change the trans oil and filter at no more than 50,000 miles with the correct spec oil. I do it myself and I have 250k on the car, it is a 2013 GLK 250...Not difficult on a lift and you do require a infrared thermometer. You can buy complete trans oil kits on Ebay for a small percentage of what MB would charge. Seeing as your vehicle has never had a oil change I would do it again. Remember, unless you have the proper flushing equipment the torque converter fluid does not get changed. There is apparently a torque converter drain plug but I have never found it...
Latest: just changed all spark plugs. Shutter still there, only when first driven a mile or so. So it's had tranny oil and filter service, new air filter, new spark plugs, looked at engine revved with brake on (fine) and transmission reset.....it's better that when I picked it up, but still there.
How fun was changing the spark plugs? Did you replace any coils as well? I just did all 6 plugs and one coil
2015 GLK350 Base
Well now having accumulated about 5,000 miles with Marvel Mystery oil and Ethanol free premium, I can state that even in 40° weather, my shutter has vanished. An experienced mechanic friend and I share an opinion that this "Direct Injection" that was forced on us without enough years of being worked out was the cause. That is the same reason so many products are having issues lately. "Hurry it to production so we can be the best mpg, the fastest, the cleanest for the environment, including EV products". It used to be a company like GM, or Ford would have one model that had the new technology and after a year or so. IF IT WORKED, it would be on most models.
Just saying.....
21 - 27 of 27 Posts
