I recently bought a 2010 E350 v6 with 96000
Miles on it. I noticed after I got it home on cold start I hear a ticking noise at idil it’s not the injectors as I can here them also. The noise seems to go away when I rev the engine past 1000 rpms it’s just a little noisy idiling seems more pronounced on the passenger side of the engine, seems to be coming from the top of engine. Car seems to run and drive just fine,
Anyone have any suggestions on what it could be thank you
SuperModerator
1986/1990 W126
Hi. You'll need to post this up in the correct section for your vehicle. This is the section for recommendations of repair shops, by region.
Of you go back and scroll down the main menu you should find the section for your car. Good luck with your issue.
