2007 Mercedes-Benz R350 / 2010 Mercedes-Benz CLS550
There's two CDs in the changer that won't eject when the eject button is pressed. Anyone experience this?
Press the silver tab under the button for your hazard lights, that will open up you stereo and then you may eject the disc
I don't have the tab you mentioned in my model.
'71 Pinto
Remove head unit (radio), need to access the internal DVD changer. Unit disassembly should be self-explanatory thereafter. If you cannot free disks, drive may need replacement. You can search ebay for “NTG 2.5 changer” and used COMAND unit (compatible part #s below) to compare cost for best remedy.
