I have a few questions and issues with the Comand Unit.
1. Other than the Nighttime/Daytime/Auto function, is there a way to adjust the brightness of the screen. I end up driving with the unit closed at night while on the freeway etc.
2. Is there a way to have a continuous scroll while using an ipod/iphone? if you want to go back to a playlist or genre etc, it automatically starts you at the beginning and not where you left it. Would be nice if you could scroll backwards, meaning from A -Z instead of A-B-C etc.
3. Tunnel mode is not turned on in my 2010 C class, can I turn it own myself?
4. I have read that european models with P2 will autmatically close windows and sunroof if rain is detected, is that a computer item that can be switched on here? Thanks!
223.168 & 213.050 & 906.633
1. it should be at the same menu as the mode selection where you can adjust brightness. Should be page 38 on your Comand manual.
3. and 4. are version coding issues. I'm not sure if it is easy for a US car, these are likely under SCN coding.
