2011 60 plate CLC200K in Iridum Silver
Hi
I have just taken delivery of my 2009 UK spec SLK350 with the updated Comand System.
Bluetooth connectivity works brilliantly - and the new HD system works well. The increased resolution of the display is great, as are the updated maps!
However, I havent found the option to display the ETA to destination on the main map screen when driving. I can find it out via a couple of button presses, but thats not much use when driving and not wanting any distractions!!!
Anyone seen a way to get the ETA on the main map??
Cheers!
Mike
SLK 350 facelift, palladium + gullwing red
Hi Mike
I haven't checked this but I'm pretty sure in nav mode mine shows actual time in top right corner and ETA in bottom right - I use North up map mode and go to full screen normally - I'll check tomorrow and post again - what colour did u get - I live not to far away - mine's Palladium
Chris
Hi Chris
Im pretty sure im in that mode too (though the car is always facing upward) - though I also get all the extended information - like how many satellites locked, height... Maybe if there is a way to turn this off I can see the ETA??
in the bottom right currently I get the signal strength of the bluetooth phone...
Mine is Obsidian Black... Always liked that colour :)
Picked it up last friday! was a good weekend to have the top down!
Cheers
Mike
Mike
It sounds like you have Go-coordinates set as a preference - you need to reset it to Arrival time/distance. Once you are in route guidance mode this will then give you the following display across the bottom of the screen from left to right - Scale/North/Distance to destination/ETA.
To change the setting: in Navigation mode
Press Navi button (top left of screen)
This shows new menu - 'mode/block area/save off road map/information on map'
Click on 'information on map'
This shows new menu - 'arrival time&distance/current street/geo coordinates/none'
Yours is probably set to 'geo coordinates' - change it to 'arrival/distance'
You should then get the info bar as indicated above.
You have probably figured how to go full screen - but it's click the up button - this shows 'full screen' then click OK button.
Hope this sorts you out - you need a PhD (or a 14yr old) to work these damn things
Good luck
Chris
Mike
By the way do you work at Maclaren cos I saw a black facelift outside Woking Mclaren 2 weeks ago?
Chris
