My van will not start it cranks over and splutters as if it is going to start but no luck.There are no codes. When cranking ,the fuel pressure is approx 250 psi then drops straight down to 9 psi.I have changed fuel filter,fuel rail inc sensors, hp pump, crank and cam sensor, full wiring loom the injectors have been checked and they are getting a pulse from ecu. The low pressure pump from the tank is working.The only thing that I have not checked is the lines to and from the tank to the filter. Is there a way that I could bypass the tank and try to start the van from a can of diesel ???? If so how do I link it up Please help it is driving me mad.....:cry::cry::cry::cry::cry:
I have tested pressure from tank to filter it is 100psi and stays there with ignition off. There is no deisel leaking back from any injector during leak off test?????????
