2008 R-350 4Matic
Hi all,
Quick question to see if anyone else has had this problem and if you have any ideas how to fix it.
Last week, for some reason, the door lock on the driver side front stopped working. When i use the remote lock, unlock, all other doors respond, but for some reason, the driver door locking knob does not go up or down or lock/unlock.
i can lock it/unlock manually once the door is closed by opening the rear driver side door and pulling the locking knob up and down.
Anyone see this before? Any ideas on how to fix?
Any help you can provide on this would be appreciated.
Regards,
2004 SL500, 2007 R350
Sounds like the solenoid (or whatever) within the door which will be awkward to fix. Still under warranty? Hope so!
2008 R-350 4Matic
Thanks for reply bobbybowie
Thanks for the reply. Yes--still under warranty. I'll take it in for sure to get it checked.
2006 R3504M, 2007 E3504M
Had a similar failure on right passenger door. Solenoid was replaced under warranty. Problem was intermittent and more frequent during warmer temperature.
