1 - 13 of 13 Posts
2008 ML350 with P0016 and P0017 codes (New-P0521)
Hello all,
I have a 2008 ML350 with 128,000 miles at about three weeks ago the the check engine light came on while driving on the freeway, a soon as I arrived home I scanned the car for codes and came up with P0016 and P0017. I asked my dealer about the codes and to see if mine had a bad balanced shaft but they said that there was no way for them to know. So I ran my VIN number and seems like mine is not affected. I put in all four new Cam Magnets but the codes are still there--sometimes the check engine light does not come on. I am still driving it as is and seems to be running fine. I also just took it to a 600 mile drive and everything seem normal, it did feel a little slow on hills but other than that everything was fine. Do you guys think I should change all four Cam shaft position sensor this time and see if that takes care of the problem?. I also check the holes where the position sensor go and the circles seem to b on the center.
Any help will be much appreciated.
Anyway to scan the car? I'd lean towards the sensors, but which one?
Not useful to throw $ on sensor replacement without some confidence that's the cure.
Might try measuring the sensors to see if there's a difference between them.
Skippy
Thanks for your help
I used the Torque app with my phone, but I cleared the codes this morning. I will scan it again as soon as the check engine light comes back on. I remember it said bank 1 position A and Position B, but i will let you know as a soon as I scan it again. Also how do you measure the sensor?
Thanks.
I just scanned the car again and now a new code is present (P0521) 16 and 17 do not show up but I'm sure they will reappear. I attached some images of the results using the Torque App with my phone. Any more ideas of what the problem could be?
Thanks.
you need a balance shaft or timing chain has stretched. you can't go by eng numbers. We have done several outside the MB so called bad batch. We have done a 10 model, a few 09 and several 08 models.
or remove front cover completely. put crank on 40 degrees. to gear marks line up with edge of head. if not than a worn shaft or stretched chain could be the culprit.
someone with a bore scope can look at gear thru right side head to see what the teeth look like.
Thank you vortec... Does anyone know of a good mechanic that can work oon this car that is close to sacramento ca.
I have a 2011 Mercedes e350 with code P0016 DTC 1208. I replaced crank sensors and all 4 magnetics. Any ideas? Thank you.
You have a few decent shops there, including Franks and Elios. I would check at the dealer first, though. If it is the balance shaft (huge bill), MB may credit you something. There was a deal made a few years back, but I don’t remember the details.
1 - 13 of 13 Posts
