Current: 2003 SL55 Obsidian Black, 2007 ML500 Silver. Former: SL500, 560SEL, 450SEL, 300SEL 6.3
The domestic goddess's ML500 (Australia) has 110,000km, she has had it for 3 years from 80,000km
Great car, no major issues except I replaced the rear airmatic bags at about 100,000km when one developed a leak
The engine has generally been slow to crank since she got it. It's as if the battery was going flat
It cranks slowly for a few revolutions then spins normally and the car always starts after, maybe, a few seconds
Sometimes those first few cranks are so slow that you think the battery is just not going to turn it over then away it goes
We replaced the battery after about the first year but it made no difference
It failed to start for the first time a few days ago. It just cranked slowly and eventually cranked no more.
It eventually fired up "normally" about 20 minutes later after she let it sit a while. She wasn't very happy
It's done it's usual thing for the last few days
I have hooked the car up to my Star Diagnosis setup on a few occasions but no relevant faults are found
I am thinking that it might be the starter itself but it works perfectly after the first few slow cranks and if the engine is switched off and then started after a minute or so it works perfectly if you count one slow crank every time.
I've searched the various forums but there doesn't appear to be anyone out there who has experienced a similar problem
Does anyone have any clue as to what might be the cause of the problem?
Peter
Peter
