You should think seriously about the extended warranty as the normal repair for this problem is a new valve body and control unit, very expensive fix.
This will not solve the problem, it will make the problem go away for a while longer and (for the Dealers) keep the car away until it is out of warranty.I have the same problem too.. 07 s550 108,000 km
Mine started last fall but i decided not to do anything about it since i planned on parking my car over the winter. (i live in Canada).
I will be taking to the dealership to have them look at it come spring...
I did some research and it is a common problem but there is no recall.
There seems to be some kind of solution acording to this thread.
http://www.benzworld.org/forums/w221-s-class/1499143-s550-stuck-transmission.html
Problem Solved!
The dealership reprogrammed the software on the 7 G-tronic once again. This time, they changed the transmission fluid and the transmission filter. Happy to report that the problem is finally solved. The car runs as new. Thanks all for your concern.
Hopefully this helps.
Try it and Please let me know how it goes.
Thank you, this is what I was looking for:thumbsup:DTB S-B-27.19/118a JUN10 – MY-All, Transmission 722.9 in Models 164, 171, 203, 204, 207, 209, 211, 212, 215, 216, 219, 220, 221, 230, 251, 463 ordering notes for Electrohydraulic Control Unit
221 – Control unit 2202701406 replaced by 2202701306 replaced by current 2202702706
It is not just the USA as we are also seeing this problem in China and others have been mentioned in UK and Australia.Does this mean all models manufactured prior JUN 2010 will need this control unit replaced ? Is this bulletin apply worldwide or only in USA ?
This is bad for owners which their warranty expired.![]()
I believe this is the 4th valve body modification so I am not taking bets on it.has the latest vb been proven to not be a complete failure? or is it just an appeasement pn replace?
I do not know the cost but the valve body and control unit are one and the same.so what is needed to change in order to transmission working without fault?
My w221 4matic wont go in any gears,its stuck in neutral.
Im reading about repleacing valve body and control unit.
Can i only change valve body or do i also need change control unit?
How much does control unit cost?
