Masarwa99, see COMPONENT LEVEL REPAIR OF MERCEDES ELECTRONICS AND...
Do you rebuild amp?Hello I do repairs on w221 amps in case you what to fix it. Sent from my SM-N950U using Tapatalk
are you still doing repairs? If so how do I cntact you?No sound?
Sent from my SM-G998U using Tapatalk
Just to add to this thread, they are cross-compatible (Pre-facelift and Facelift). I bought one from a 2007 untested for $100 at my local junkyard and it worked on my 2011. Flipped the fan (So the air blows outwards, not inwards) to fix the amp issue and works like a charm.
[/QUOTE
What ? What ? and what ? Ya got 07 amp untested and all you did was reverse all cooling fans outwards in purpose of getting hot air out instead cool air in then it works every single time when audio turn on ?
If this is a true statement then German engineering is not a greatest![]()
alexender63 : Are you serious repare man on these trouble amps ? You are sure to understand our members has few and same common problems with this amp so let's straight arrow here by tell us what your specialty and flat rate including flat rate on shipping return. PLEASE and THANK YOUNo sound?
