41 - 60 of 60 Posts
1979 280CE
I pmed streetglower and he said to remove the console side carpet panels to see the drain hoses. I don't know how to remove the panels without breaking them, do you? Thanks i'll take a look this weekend.
2006 CLK 350
Discussion Starter · #42 ·
Sorry... don't know how it comes off...:surrender:
When you figure it out, please post it here so we can learn too!! :D
Good Luck and have Fun this weekend... :thumbsup:
1979 280CE
I'll let you know. Does your CLK leave a puddle of water when parked?
2004 CLK 240 Coupe
I find it hard to believe that a/c drain hoses are located there. Possibly he means drain hoses from the sunroof..?
Drains from the a/c will be within the engine bay, surely.
2004 CLK 240 Coupe
I took a look today after parking.
Water drips in two puddles under the car - more or less in line with the side mirrors. Without getting underneath and removing the plastic covers, I can't see the a/c condensate tubes....
1979 280CE
There are 2 tube above the tranny. I would remove the side capets but I don't know how.
There is absolutly no water under my car after driving.
Keyhole, does you AC have the awful smell?
2006 CLK 350
Discussion Starter · #47 ·
It's too foggy and cool to use the A/C here in San Francisco... so don't know if there is a puddle or not. But am sure there would be if it were hotter!
1979 280CE
Well I pulled off the side carpet and I found the drain line, I haven't done anything yet because the wife was home. My plan of action is to cut the rubber line and stuck a shopvac to it and stuck out all the crap in the heater case, and re connect the hose using a piece of metal and hose claps.
She would be all over my a$$ if I took here car apart and she found out.
2005 CLK 320, 1988 300E
I have the same problem of stinky ac at startup...
The smell is more apparent when the car has been parked in the sun for a while like when i start it after work at around 4 PM...
Still think condensate not draining?
Thanks!
2004 CLK 240 Coupe
Sorry - I'm a bit late on this, due to 'inattention' ....:)
No - no smell from the a/c. But I always get a 'fishy' smell from the cat at start-up, and I wonder if that air is being drawn from the cat/exhaust by your a/c.
Do you start your car in your garage, or an enclosed area?
2006 CLK350 Coupe
I also have an 06 CLK350, the filter is on top of batt like said by a few peeps,
however you can get just a paper filter or a carbon/charcoal activated one for replacement FYI
I can get an activated charcoal filter from on of the online parts retailers... but does it harm or effect the climate control system in any way?
2006 CLK 350
Discussion Starter · #53 ·
:thumbsup: Dang!!! This old thread is still alive and kickin' with over 375 hits!!!!
The 06 CLK 350 does NOT have a charcoal filter below the glove box, BUT
the 06 CLK 500 DOES HAVE the charcoal filter!!!
The charcoal filter will not harm the A/C system... it filters the smell from circulating through the A/C and the cabin. Just remember to change it or the air flow will be reduced.
Carbon pollen filter is under the glove box in 2006 CLK500 (W209)
1) Turn latches (arrows) on recirculating air filter housing in passenger foot well 90° counterclockwise (open). To close during Installation, turn 90° clockwise.
2) Remove cover with recirculating air filter (2) towards bottom.
3) Open recirculating air housing.
4) Remove recirculating air filter.
NOTE : The recirculating air filter cannot be cleaned, it always must be replaced.
5) Installation is in the reverse sequence
**BUMP** this thread because is contains some very good information.
I will probably need to change the charcoal filter in the wife's car
2003 CLK55 AMG W209
wow this thread helped alot..im thinking my 2003 w209 clk55 should have it too as i have the filter button on my climate control
2006 CLK500 Cab with AMG package
This thread is alive again! Anyone know where to get the 2006 (w209) charcoal filter?? Doesn canadian tire carries it?? I know you can get the cabin filters on ebay for like $20 bucks
2006 CLK 350
Discussion Starter · #59 ·
Hi All...... glad to see this thread still alive!!!
So the cabin filter on top of the battery can be of two versions... paper filter and paper charcoal dust filter.
The charcoal dust is just that... a light coating of activated charcoal on top of the white paper filter.
It can be found on eBAY by searching for the vendor keenanmotors4311 , he has the OEM version for $32, but there are other vendors for less ... down to $20 for non-OEM.
2004 CLK 500 Previously: 2001 CLK 430
Great thread, ok it seems this filter thing is pretty confusing lol, i thought i was buying the charcoal filters for underneath the glove compartment (i checked i do have them), but got the one for under the battery.
Well now I have a new one for there, looks like it needed a change anyways.
41 - 60 of 60 Posts
