Hi All,
I just bought a CPO 2006 S430 and need to get the "straight story" about what to do to enable the phone and sat radio:
Phone
There's no puck in the console
I have a Motorola Razor V3
I'd like to use the external antenna and have the charger attached
An aftermarket store quoted $2,400 !!!??? But I see pucks advertised for a few hundred dollars.
Sat Radio
No registration numbers come up on the screen. Do I need TeleAid to get sat radio? Same aftermarket store wanted $800 and to install a second antenna !!!???
Is it possible that there is no wiring for both these accessories?
Any and all help GREATLY appreciated? Thanks!
Here's what's needed to install phone in 2005 S-class, 2006 is probably similar.
http://phdwebsite.powerpulse.cc/Phone Install Bulletins/2005 S.pdf
This instruction combines voice control installation with phone installation, but it's not mandatory to install both.
Folks at Welcome to AWS for Mercedes-Benz can probably assist you via telecon to describe the process.
Very good information is also available at the "sticky" post above this one, i.e. "How-to Guide ... ."
There's probably a need to install a sat radio receiver in your trunk, but the wiring to the dash is probably already there, as is the antenna.
Current installation instructions for both systems are very likely available via subscription at http://www.startekinfo.com
Both installations require dealer programming to indicate "present" as regards these components.
