Hey guys. I have a 2006 ML500 W164 model and from time to time, I get messages on the multifunction display about the ESP, ABS, active headlamps, run-flat indicator, and a few other things totally up to 7 messages (although some days it'll be anywhere from 2-6 messages) along with a Check Engine light sometimes.
Usually the car runs just fine but sometimes you can feel the brakes giving a throbbing resistance and the engine won't switch gears properly (most likely that emergency mode talked about in the vehicle manual).
From the several times that I've take the vehicle to get serviced, they said the driving tests and computer diagnostics couldn't find anything and this problem has occurred more than once. Actually, right now it seems to be a constant issue rather than going away after a few hours like previously. I have a feeling this issue is an electronic one due to a bad part or a blown fuse or something.
