Hello, I am having the red message, low voltage conv. features have been disabled error. I have replaced the BCM with another used working one, same result. I checked the inline Aux battery fuse and reading 5 ohms, should this be a dead short like traditional fuses? I took the K57/2 relay out of the car and tested that it was closing when 12v is applied as it should and it is. Alternator is tested and good and I am getting good voltage on my batteries when driving 13.5-13.8. Any other suggestions? Codes are 9091, 9092, and 9071 which is why I tested all the items mentioned. I also have good continuity from the K57 relay to the Aux battery. The error message will come and go as I drive sometimes. It usually takes several miles of driving also to appear after sitting all night. Possibly heat related? I do live in AZ and it is very hot right now 105 - 110. I am leaning toward replacing the relay even though it is testing fine outside the car. Just doesn't't make much sense that it would be anything else. Any suggestions would be greatly appreciated.
