I'm in the USA and want to buy Zimmermann part number 400.1437.52 or 400.1437.53
The regular Zimmermann rotors are a dime a dozen online and I've used them twice already.
400.1437.52 is drilled not solid
Automotive tire Font Material property Circle Automotive wheel system
400.1437.53 is the proprietary black coated rotor with the Z logo slotted into the rotor
Automotive tire Product Rim Font Material property
See the pics that I attached
Thanks guys!
Product Rectangle Font Material property Screenshot
Discussion Starter · #2 ·
I'm bumping my own thread in case anyone out there bought these special Zimmerman rotors
Moderator
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, 2005 E320 CDI, and 2006 S500 4Matic
Doesn't look like anyone has.
What's wrong with the regular drilled Zimmermann rotors? I use them on our W211 and several of our W220's with fine results.
I'm close to giving up, since my rear brakes are close to being metal on metal (only a couple mm of wear left)
Where online do I get the sport drilled rear rotors in/shipped to the USA? Part number 400.1437.52
99' E320, 00' E320, 03' E320T, 05' C230K
W203s with sport brakes (949) have the same rear rotors as W210s (excluding the face lifted E430 4matic and E320 wagon).
That said, StopTech makes drilled rotors for the W210 rear (regular and cryo). Tire Rack carries them. They have left and right rotors listed so holes might be directional.
Stock W203 front rotors (949) are directionally drilled for left side but are used for both sides. You might have to take this into consideration if you want to match rear rotor holes direction to the front rotors.
