1 - 15 of 15 Posts
2005 W211 E500
Snapped a bolt in the red circle within the image. Any ideas what this part is called? and how I can take it off now? I was going to drill out the screw, but I don't think that would work in this situation. Any help would be greatly appreciated. This is on the front passenger side if that helps.
2006 E350
Looks like a "ball joint".
If I am correct, it is on a taper.
You have to bit the item hard on the solid surface to shock it off the taper.
Some repair places will have a triangular fork shaped tool that might remove it.
2005 W211 E500
Can you use a triangle tool to take it off? I imagine the bolt was treaded in there. If not, I could just take a flat head and try to pry the 'ball joint' out.
2005 E320 wagon
The ball joint pin shouldn’t be threaded to the knuckle upright. I don’t know how you’d use a pickle fork on a loose knuckle. I think you’re better off with whichever of these you can get to work:
Sixto
05 E320 wagon 174K miles
Dallas, Texas
Traditional separator will not work. There is nothing to push on if it broke flush with knuckle. Fork in air hammer would be my choice.
Reactions: Noodles
2005 W211 E500
Discussion Starter · #8 ·
Unfortunately, I do not have an air hammer. Any other suggestions, alternatives with common hand tools?
Dallas, Texas
the forque
the fork would be the cheapest tool , how can you snap that piece off ??? , never seen that .
2005 W211 E500
Discussion Starter · #15 ·
I did it boys and girls. Went to harbor freight to get one of these tools and was able to get it out. Took a little bit of effort to finesse it out, but I am happy. I'll try not to over-torque these bolts next time. Harbor Freight has a father's day coupon for 20% off until Sunday so this took the sting out of the purchase for the kit. Thank you for all your suggestions :D. Ordered new ball joints on FCP Euro they won't be here for 2 weeks
199387207_386451976089095_3349114044177588576_n.jpg 196694311_344343130651562_1752205514683169832_n.jpg 195194122_643947630339471_1205789915289050334_n.jpg
1 - 15 of 15 Posts
