1 - 8 of 8 Posts
W211
I desperately need some help and info from all of you. I'm facing a problem with NO SOUND after i replaced my Audio 20-CD with 2009 Mercedes Benz W211 E350 E550 E63 HDD NTG2.5 Navigation Comand 6 DVD Changer.
So far that I concerned, the NTG2.5 that i bought has been installed with car that has HK amplifier in it WHICH i haven't got any HK system in my car.
I already bought All the harness kit in order to convert wiring system:
1. CABLE RETROFIT GPS MERCEDES W211 W219 AUDIO 20 COMAND NTG2.5
2. ADAPTADOR ANTENA FAKRA RETROFIT
3. MICROFONO MERCEDES COMAND NTG 2.5 MICROPHONE RETROFIT
4. ANTENA BLUETOOTH MERCEDES COMAND NTG 2.5 ANTENNE
5. GPS ANTENNA
Everything is perfect, the cluster instruments also detected/read the NTG2.5 unit but SOMEHOW there is NO SOUND comes out AFTER ALL.
What should I do PLEASE?
Must be a version coding issue, your new COMAND is configured for the external amplifier and you should reconfigure the MOST ring to no devices present.
W211
Therefore just coding it and the problem will be solved? can official MB dealer do that coding thing? Thanks for the info
They should be able to do it but it isn't always exactly straightforward to reach the control unit from SDS. You should find instructions from some NTG2.5 retrofit threads.
W211
Thanks for the guidance Diesel Benz. i'll look the thread regarding NTG2.5 retrofit.
Cheers
2004 E55
Any outcome on this? I'm having the same issue, no sound. My car had hk on my old ntg1 and upgraded to ntg2.5 with hk and no sound, any tricks or something I'm missing?
If you have HK that mean there is an amplifier, just go to hidden setting and turn external Amplifier ON.
1 - 8 of 8 Posts
