My top won't close all the way can u please help me and tell me what u think the problem is thanks so much
If Viagra doesn’t help to get it all the way up, you may try posting the problem in the R230 Forum.:devil
We in this forum usually don't know much about your car which is R230, but chances are the controller is not getting the expected signals from sensors (micro-switches ?), so it can't proceed.
Moderator
You need to pull codes, there is probably missing signal from certain sensors/micro switches... either bad switch, or misaligned component
This aid will help greatly. When mine would not close, it pointed right to the S117 microswitch. If this is your problem, the post the switch is supposed to contact is famous for getting just a little worn down and it will not complete the circuit. You can replace the post or beef it up a little bit. I just put a zip tie around the post and clipped of the excess. Worked like a champ with no issues for almost a year now.
Good luck.
