1 - 13 of 13 Posts
Just out of the blue, the front windows won't soft close after opening and closing the doors. Also, the rear windows went down like normal but neither will raise back up.
Any ideas?
'03 SL500's Tanzanite Blue, Aegean Blue, Mars Red, Alabaster White '11 S550 Flint Gray
Sounds like something in the roof sensors might be getting ready for causing more permanent trouble.
That's the way I was leaning. I think the only thing that blocks window closing is the roof not fully open or fully closed and latched. Motors and door modules are independent, so they wouldn't affect both sides. Diagnostics on the door module will tell you if the windows are blocked and status of the window switches, I would at least start with that.
2004 SL500AMG, 2003 SL500 USA model, Auto Transmission, Stock, Aegean Blue Metallic
Transmission fluid level is checked using shop dipstick. Only reason to hook up DAS is to read fluid temperature in D or R. Open WIS and search for article ar27.00-p-0100ac
Is this a 2003 or 2004 SL500? Doesn't 2004 fill from bottom of transmission pan (no dipstick)? No electrical connector also.
Once you enter VIN in search mode select full text search and enter search term "oil level". To narrow down search results uncheck all groups and select group 27 only.
Have you entered search term?
What is that supposed to do?
this synchronizes the windows. It may be required after the battery is disconnected. It may be required to operate the vario roof completely. Hold both window switches up for one extra second after the windows reach the top. This is in the owner's manual.
Ditto on fully charge both batteries, and or verify that voltage with engine off exceeds 12 volts. If unable to exceed 12 volts, replace the rear / accessory battery.
00' E320, 03' E320T, 05' C230K
Looks like you need to resynchronize your "quotes" :)
Reactions: Witek_M
Reactions: 260e crusier
1 - 13 of 13 Posts
