2K1 C320 SS
Can the wheels from a 2005 SL fit on a C Class
front wheels are 18x8.5 ET35 and the rears are 18x9.5 ET40 can it fit on a c320 2001
and can 255/40/18 tires fit on the rear wheel and 225/40/18 in front
OR THESE
Sizes: 18x8.5" or 18x9.5"
Offsets: ET 30, ET 33
Bolt Pattern: 5x112 mm
HELP PLEASE
2002 C230k
SL wheels cannot be used on a C. The SL wheels use 14mm bolts and the C uses 12mm bolts.
2K1 C320 SS
TIRE
ok so whats the biggest size width of tire u can put on the rear wheels if your rims/wheels are 18x9.5 wide or 18x8.5 wide
can u put 255/35/18 OR 245/35/18
18x9.5 18x8.5
2002 C230k
RE: TIRE
A 265 on a 9.5" wheels will fit in the rear. But pay attention the diameters of the front and rear tires. They should be very close the same, or it will confuse the ESP. A confused ESP will not lead to anything good.
2K1 C320 SS
Discussion Starter · #5 ·
so what size tire will fit on a 18x8.5front and 18x9.5rear without driving the ESP Crazy what size tire do u recommend?
2002 C230k
Front: 235/40 ZR18
Rear: 265/35 ZR18
But, you really should call Luke and talk to him about what you need. He is a professional and I'm not.
