1981 380SL 151K: 2005 S500 116K: 2006 E320 CDI
In another thread, I had an electrical issue which was eventually discovered to be caused by water that had entered the passenger side floor and corroded a connection. That thread is here and explains what took place up to this point.
FIXED! 2005 S500 4Matic: Key will not turn in EIS
This thread picks up from the above thread as I try to save the car from suspected reed valve blockage.
While discussing the outcome of my previous issue with my indie, he strongly suggested drilling a drain hole through the plastic electrical cable channel that contained the corroded harness connection and out through the bottom of the car. I have my doubts about the ability of water to drip from a hole in a plastic box directly into the additional hole in the steel car floor to the outside. I'm imagining a very soggy outcome but...is it really a dumb idea if it works?
I'll begin with the usual suspect, that damned drain and if it is indeed clogged, I'll simply have to be more vigilant in the future.
