Purchased it over the summer of 2022.
88,000 miles (will go up as this is my daily driver)
The bad:
The good:
The bad:
- One small chip in the paint(pictured) next to the gas cap. Otherwise the paint is a solid 9/10 for the age.
- Steering wheel is stuck in the up/down position. (in/out motion works fine.) The motor still works so it is most likely the small white plastic piece inside that is cracked.
- Drivers side bottom seat cushion has a few tears
- Could use rear brake pads
The good:
- Everything else inside and outside of the car works exactly as it should.
- Brand news Michelin pilot Sport 4 All Season Tires. Less than 2,000 miles on them
- Brand new Bosch starter installed 3,000 miles ago
- Rear main seal done 02/21/22
- Fresh oil change
- Aftermarket radio; double din touch screen, steering wheel control
- Apple carplay
- Aftermarket rear view camera
- Folder full maintenance records
