1997 E320
Hello everyone i have this car at my shop and after a 30min drive the vehicle has no power will not shift down. I pull up codes 2526-004 "test signal cable to component y100/1(right charge pressure positioner)" signal line is interrupted. As far as i understand this is to do with the electronic acuator for the wastegate. After talking to the dealer they say the acuator or sensor is non replaceable and will need a new turbo at a cost of $2400.00 i can't believe this part is non replaceable, has anyone every run into this or have a good source for a turbo thanks
Adriaan
'03 Z4, '02 E55, '11 ML350
Hello Jankebenz.
Just a suggestion but you may want to post your question in the standard W210 forum as this is the AMG forum. No diesels for these folks here. :D
You'll most likely get a faster response.
Good luck.
Mike K.
1997 E320
Yeah i was trying to figure out where it was and why i hadn't gotten any responses but it in the wrong forum. sorry and it's a 05 so it's a 211
