So, my wife's CLK320 (110K miles) has been sitting during this COVID thing; not getting a lot of driving. I replaced the battery when it failed to hold a charge (7 years old, so expected).
Recently got around to replacing the passenger side valve breather gasket to eliminate the occasional drops of oil landing on the manifold and offering that pungent burnt oil smell through the cabin air cleaner. Done. Problem solved
Now I am getting four errors showing up all of a sudden:
The right front turn signal does not light (fast blink when activated, but side mirror and rear light work fine). I replaced the bulb with a spare that had been sitting in the glove box for years, and it still does not work. Could be a bad replacement bulb, so I will next check with the bulb from the left turn signal, and/or buy a new one.
But, the washer fluid is full and so is the coolant reservoir. I topped both off just to be sure.
Finally, there is evidence that some mice have been chewing as I see some foam bits that have been chewed and a group of ground wires screwed to the top of the right fender have been chewed. We live in a rural area and have plenty of field mice to try to fend off especially during the spring and fall. My truck usually has tiny shell deposits on top of the engine that testify to the issue. It is parked outside. The Benz is garaged, but that is far from foolproof of course. Recently I was doing some overnight work on my truck (axle seal and ball joints) so the Benz sat out overnight, pretty rare occurrence. Though they never ave done this in 15 years.
I note that the ambient temp sensor, coolant reservoir sensor, and right blinker are all on the right front side of the engine. I believe the washer sensor also comes from that side even though it is on the left center.
Q: Anyone have advice on how to troubleshoot? Perhaps a common ground/wire harness, etc.? Anyone have diagrams to assist? I know I can do the tracing and try to reinvent a wheel, but it would sure help to get a few clues/hints, etc.
Thanks for any advice.
- check coolant level
- check wiper fluid level
- bad right front turn signal
- -40F degrees on the main display all the time
