2005 CL600, 2008 E350
I just got a pair of s55 AMG front brake calipers, when I tried to put the calipers on my cl600, the bolts were larger. What are all the parts I need to change and replace so that the calipers and rotors will fit properly? Also, I have 20 inch rims so I have no clearance issues.
Discussion Starter #2
I did some more research, so everything is the same between a Cl600 and CL55 besides the protective plates, the steering Knuckle, and the rotors. For the steering knuckle you can just drill out 1mm or replace with the bottom parts number, and the protective plates can also be cut to fit the new larger rotors.
The following parts are what would be needed if replacing.
Protective plate: A220 420 13 44 & A220 420 14 44
Steering Knuckle: A220 330 41 20 & A220 330 42 20
I didn't buy rear calipers because it didn't seem to make that much of a difference.
