I have a 2005 c230 that was in a wreck. I took it to an auto body shop to straighten out a part of the frame rail in front of the subframe where the face bar bolts on. They told me that everything was straight. Heres the problem, when looking at the front wheels, it appears that the right side has too much negative camber and the caster is off slightly. The left side is fine so I don't think that the subframe shifted. Also, all of the body panels line up correctly, so I think that the fender apron and shock towers are in the correct positions. What else could be causing too much negative camber?
C230K Sport Sedan
Finding an honest good, well equipped body shop is tough. It's easy to make body panels fit, just put enough bondo on it. Take it to a place that has a hydraulic frame straightening jig, they will be able to check it to factory specs and tell you how close to perfect it is. Small body shops eyeball it, good enough for you eyeballs, not good enough for me as you'll have future problems with tire wear, handling and braking. For me, I usually just dump the car after a frame bending experience as I've never been happy with the work done by anyone. Try taking a paper clip, bend it up and then bend it back to the original shape. Not easy to make it perfect again, is it? Same with your frame.
2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
Do you have a before and after printout from the frame alignment rig that shows the amount the frame is off after the corrections were made? Most laser equipped alignment rigs can get you within +3/-8mm if the frame tech is any good. You need to verify all deminsions since collision forces could have displaced the entire subframe upwards and to the side without obvious damage to the sub frame. Since the C Class has a strut type front end any misalignment between the sub frames suspension tie points and the shock tower bearings will cause your problem.
If the shop cannot provide you with a printout they may have "eyeballed" the pull on the garage floor using a chain hoist tied to the floor. If they did this get yourself to a shop that has one of these:
http://www.framefacts.com/
You may also wish to file a claim for "Diminished Value" and these guys are the only specialists I know of in that line of business:
http://www.collisionconsulting.com/
