2002 C320, 2004 ML500
My MCS suddenly stopped receiving antenna signal the other day. I checked CD and that still plays. Cannot get a signal on antenna FM or AM. I also have a sirius/XM FM connection hooked in and that does not work as input. Seems to be the antenna feed to the head unit.
Has anyone had a similar problem or have a fix for this issue?
1999 E300TD
Its been a long time since ive worked on these audio systems. Check under the front passenger seat at the teleaid module to make sure all conections are good. send me a message tomorrow and I will check the main antenna at work tomorrow
No problems there. I pulled head unit again and tried a replacement antenna and got no result. I believe the antenna module in the unit must be bad.
Plan is to go to an aftermarket system with more capability. Thanks for help.
cb
