1985 500SL - 2002 SL500 Silver Arrow Edition
Just got a 2004 E320 and it has a strange quirk. I turn the key to the start position and there is a 2 second delay before the starter engages. Sometimes it will not crank at all and I have to take the key out and re-insert. The battery is fine and the key fob battery seems fine as well. Any guesses? Nothing to trigger a check engine light.
Would the immobolizer be throwing a code that wouldn't show on the dash?
When it won't crank I have messed with the gear selector to see if its the neutral safety but that does not seem to be the culprit.
Starter solenoid?
E350 4M 06
if you havent done this already I suggest you change the key fob battery and clean both ends of the contacts. Another long shot is the aux battery, I hear strange things happen in the electrical system when it goes, you may want to check it, its under the cover in the corner (pass side) by the cabin filter
