1 - 18 of 18 Posts
2004 E-320
Hello everyone. The red battery light came on a month or two ago and i went in to the dealer and they diagnosed my car saying i need to have the secondary battery changed. They want to charge me $330 for the whole job. I was wondering if this is easy to change so i can do it myself? If anyone has a link or knows where i can find one for purchase online that would be a great help. Also any tips on replacing it would help also.
Thanks in advance!
-Slice
2004 E-320
thanks for the replies. I've got to look more into this post on one of the threads you linked:
"Since you've "worked as a mechanic," you surely know the value of following factory procedures.
To replace the aux battery requires disconnecting ground cable of main battery.
Doing that requires "perform basic programming" which means set clock, normalize power windows and sunroof and activate steering angle sensor.
You're also supposed to connect connect Star Diagnosis and read out fault memory".
My stealer wanted $300+ to replace the aux battery. I went to Sears to buy the BS14 but was told by the mechanic it was not a good idea because it was NOT SEALED. So gases would escape...right into the cabin air filter. He refered me to the local BatteryPlus store. Their X2-14 by Ascent Battery Supply (for Harleys & Honda mcs)was the exact size cost $95 +. It's advertised on their website for $10 less, but I did not check. Car's cables had an L shape fitting that need to straighten easily w/ pliers. Bolts right in. I installed without disconnecting the main battery, using great care not to arc anything and took 15 minutes.
Purple Moderator
The Sears Gold BS-14 is a sealed battery. The do sell a cheaper one that I did not look at.
This is a quote from the product description.
Product Description
DieHard Gold PowerSport Battery featuring AGM technology may also be used for Motorcycle, All Terrain, Snowmobile, Watercraft and Lawn & Garden.
* Battery Type Maintenance Free
* Sealed design eliminates spilling and allows for installation in any position
* Pre-measured acid with easy pour bottle eliminates guesswork when filling battery
* Compressed plate packs protect against damage due to vibration
* 9 month free replacement limited warranty
* OEM JIS Part Number: 14-BS
2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
Not too sure the Sears battery is a true "AGM" other than their claim that it uses "AGM Technology" which is not the same as a true "AGM". The give away is that you have to fill it with acid, AGM battery's do not have "Free Acid" in them and is completely absorbed by the glass matting material.
The true test of an AGM is to see if it exempt from hazardous shipping restrictions for air shipments, all AGM battery's are exempt from air shipping restrictions and you can ship them with the same limitations as an empty box by air.
Well the Sears mechanic did not want to sell their product for this application because it would vent the gases into the cabin, so I'll go with drivbiwire's logic that if you can fill it, it will leak gases if not liquids. Why else would they turn away business, and refer me to Battery + ?
E500
Interesting. ON line vendor would not ship me MB part OEM battery due to hazmat restrictions.
I have also seen AGM batteries shipped dry where acid was poured into the battery, then sealed. After 1 hr of sit you could not pour any acid out as it was all adsorbed in the mat. But it might have been AGM type battery. In any case nothing spilled out when attempting to get it to pour our.
Purple Moderator
Well seeing as Sears claims the battery can be mounted in any position I am guessing that
the acid is also absorbed fully or it would have acid moving around in the battery. That
is something that would not work well in Jet Ski or snowmobile with all the bouncing.
As far as the venting issue of fumes I can not comment. I have no problem going to try
the Batteries Plus unit. I am not in need right now, but when the time arises the Batteries
plus nearest to me is managed by a neighbor's son. He has all of the BS-14 AGMs in stock.
The top of the line will be 89.99 at retail in this region. I will get the discount that drops
it to $75.
Based on all the info so far I am now leaning towards the Batteries Plus unit.
Here is the specific reference of the shipping laws:
49 CFR 173.159(d) states:
A nonspillable wet electric storage battery is excepted from all other requirements of this subchapter under the following conditions:
1.The battery must be protected against short circuits and securely packaged;
2.The battery and outer packaging must be plainly and durably marked "NON-SPILLABLE" or "NON-SPILLABLE BATTERY"
3.The battery must be capable of withstanding the Vibration and Pressure Differential tests specified in 49 CFR 173.159(d)(3)(i) and 49 CFR 173.159(d)(3)(ii); and
4.At a temperature of 55°C (131°F), the battery must not contain any unabsorbed free-flowing liquid, and must be designed so that electrolyte will not flow from a ruptured or cracked case.
Regular lead acid however is more restrictive and must be classified as "Class 8, Corrosive" along with all the other associated HAZMAT paperwork requirements. This classification often will prevent you from shipping them by FedEx or UPS by air (aka Overnight or Express). Most shippers will refuse to even ship it because of the increased liability should the packaging fail in transit.
49 CFR 173.25(A) states:
Authorized packages containing hazardous materials may be offered for transportation in an overpack as defined in 171.8 of the subchapter, if all of the following conditions are met:
1.The package meets requirements of 173.21 and 173.24 of this subchapter.
2.The overpack is marked with the proper shipping name and identification number, the air eligibility marking, when applicable, and is labeled as required by this subchapter for each hazardous material contained therein, unless markings and labels representative of each hazardous material in the overpack are visible.
3.Each package subject to the orientation marking requirements of 172.312 of this subchapter is packed in the overpack with its filling holes up and the overpack is marked with package orientation marking arrows on two opposite vertical sides of the overpack with the arrows pointing in the correct direction of orientation.
4.The overpack is marked with a statement indicating that the inside (inner) packages comply with prescribed specifications when specification packagings are required, unless specification makings on the inside packages are visible.
5.Packages containing Class 8 (corrosive) materials in Packing Group I or Division 5.1 (oxidizing) materials in Packing Group I may not be overpacked with any other materials.
Note: “Battery fluid, acid” is a Class 8 (corrosive) material in Packing Group II. Therefore, paragraph 5 above doesn’t apply.
95SS(165k) 06CDI(SOLD) 2014 GLK250
A lot of places just hear that your trying to ship any kind of car battery and refuse shipping even if its ok by law it sometimes doesn't make it past the bozo working the shipping counter, especially if they don't do it regularly
E500
If it is really ok to ship the aux AGM battery,, this is probably why mine was cancelled 1 week after I was told it was shipped. I was forced to buy a new one from the dealer at $151 vs on line. That is when I found the aftermarket AGM's that meet the spec.
And you are probably right,, Bozo is probably who cancelled the order after a week in shippment. Wonder how they go it back. UMMM smells like old fish on this one!
I wouldn't worry about the extra money spent, the Benz battery is worth it to me, $50 bucks is a hard hit on the chin but for the correct part with the right terminals and you know it fits and works/chargers properly cant compare with saving a few bones and jimmy rigging a battery to work in there...
thats just me
Mercedes is not manufacturing batteries.
For my older models one time I called MB roadside assistance that did "free battery exchange" but charged me $190 for 24 months warrantied battery.
For the second car I went to Costco where $85 bought me 100 months battery.
The batteries MB puts in the cars are usually good ones (the one in our ML320 is in service for 12-th year) but their warranties suck.
Took advice
I took the advice and ordered the x2-14 agm motorcycle battery from batteries plus in NJ and installed the battery yesterday. So far so good. I live in ct and they shipped it with no problems. The lady at the store said it was agm and used in motorcycles. It Cost 110 dollars with shipping. There was no poured in acid al the connects worked fine with limited tinkering. Exact same size as the fiamm battery aldready in there. Only took 15 min to install. I will let you know if the light comes back.
1 - 18 of 18 Posts
