1 - 9 of 9 Posts
2004 CLK500 AMG Package
I HAVE A 2004 CLK 500.. HAD THE CAR FOR LIL OVER A YEAR.. SRS LIGHT CAME ON OUT OF NO WERE TODAY WHILE DRIVING.. SAID SRS BRING TO WORKSHOP ANY IDEAS ON WHAT IT COULD BE OR HOW TO RESET IT OR FIX IT? I SEARCHED AROUND I DIDNT SEE ANYTHING USEFUL ONLY REASON WHY IM POSTING THIS ... THANKS... -- RYAN
2004 CLK 240 Coupe
Please don't SHOUT, and add some details using the UserCP ^^^^.
It's not possible to diagnose SRS faults via a forum. Best thing for you to do initially is to get the fault codes read. It could be something to do with any front seat belt buckle switch, or an airbag sensor fault, but as it is a safety feature you should check it out asap.
2003 clk500
like most guys said it cannot be 100% unless you check your error codes, but i had that same problem recently and when the shop read the fault codes it came back as i believe it was to much resitance or voltage..and the shop said something about installing a resistor for the airbag connector. the shop said alot of clk class cars do that and its a simple job. but that isnt the only possibilty it could be something else always better to get the fault codes check just incase it might be a biggeror smaller or different issue that might need urgent attention.
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Here's a list of the SRS codes:
B1010 states that the ignition squib for the left rear seat belt pretensioner has a short to ground. Remove the rear seat cushion and check the wiring for the squib. It should be a green connector that plugs into what looks like a metal pipe under the seatbelt latch. Check for any obvious wiring issues - cuts, chews, crimps, etc.
1 - 9 of 9 Posts
