1 - 20 of 50 Posts
2004 CLK320
I'm pretty sure this topic has been covered but my search did not show many posts with DIY Rotor/Pads Replacement....So here's my experience so far.
My local Merc shop quoted me (not kidding) $1,557.00 USD to replace the rotors (OEM), pads (OEM), brake wear sensors (OEM), labor and a shoe up my ass on the way out the door......no thanks.
I purchased the following to complete the replacement from R1 Concepts. Disc Brake Rotors & Pads | R1Concepts.com (They are great to work with)
EDS.35058 Performance Cross Drilled Slotted Disc Brake Rotors (2)
EDS.35034 Performance Cross Drilled Slotted Disc Brake Rotors (2)
105.08720 Posi-Quiet Ceramic Disc Brake Pads with Shims (1)
105.08760 Posi-Quiet Ceramic Disc Brake Pads with Shims (1)
117.35027 Disc Brake Hardware Rear (1) optional
Total = $327.35 (Shipped in 2 days from California to Kansas)
CRC Disk Brake Quiet - $4.99 USD
Permatex - Threadlocker (RED) - $5.99 USD
VersaChem - Anti-Seize Lubricant - $3.99 USD
Torx Bit Set - $14.99 USD
Brake wear Sensors (2 x $11.99/ea) from Mercedes Benz - $25.00 USD
Total = $54.96
TOTAL PARTS & SUPPLIES COST = $382.31
What you will need:
Floor Jack & Wheel Chucks & Jack Stands
17mm Lug Nut Socket - to remove wheel lug nuts
12mm Wrench or Socket - to remove caliper bolts
18mm Wrench or Socket - to remove caliper housing bracket
Torx bit (9mm i believe) - to remove Torx screw on Rotor
Rubber mallet or Hammer (if you don&#8 217;t have a rubber mallet)
Caliper clamp or C-Clamp or strong pair of hands
Torque Wrench (If you have one available)
Wire Brush
Step 1 &#8 211; Remove wheel and place jack stand in proper place for safety.
Step 2 &#8 211; Remove caliper. Since you are replacing the rotors and pads, I took a flat head screw driver and with a little force placed it in between the old rotor and pad. Push lightly in the opposite direction of the rotor to recess the caliper just slightly to create enough room to remove the caliper. Remove upper and lower caliper bolts (12mm). Remove caliper housing and set onto your second jack stand so the caliper housing is not dangling from your brake lines. A major no no! Remove the existing brake pads and keep them close by. They will come out easily. (They will come in handy later)
Step 3 &#8 211; Remove upper and lower caliper housing bolts (18mm). Set the caliper housing bracket aside for now.
REAR CALIPER top Bolt
Step 4 &#8 211; Remove the Torx screw with your Torx bit and socket wrench to free the rotor. Once the screw is removed you will need to use some brute force to remove the rotor. A couple of persuasive whacks on the rotor&#8 217;s outer edge with the rubber mallet and the rotor will free itself.
Step 5 &#8 211; Recess the caliper back into the caliper housing using a caliper clamp, c-clamp or your hands (good luck). Be careful to recess the caliper slow and steady or else you risk damaging the master cylinder. If you recess the caliper too quickly it will send too much pressure back through the lines to the master cylinder and possibly cause damage or completely blow out the MC. I decided to keep the existing brake lines and choose not to replace them as they are in good condition. If you are not replacing the lines, there is no need to bleed the fluid out of the lines first.
Step 6 &#8 211; On the bearing hub, you will want to take your wire brush and clean off the bearing hub from old brake dust and other particles that may be stuck onto the hub. Then, squeeze some of the anti-seize ointment onto your finger and apply a thin layer onto the bearing hub against the bearing plate.
BEFORE CLEANING AND ANTI-SEIZE APPLIED
AFTER CLEANING AND ANTI-SEIZE APPLIED
Step 7 &#8 211; Put the new rotor onto the hub and replace the Torx screw with the thread-locker gel applied to the Torx screw.
Step 8 &#8 211; Replace the caliper housing/bracket with thread-locker applied to both 18mm bolts and tighten firmly.
REAR
Step 9 &#8 211; Put new pads into place with the disk brake quiet ointment applied to the outer backing of the pads. (In the pic above I had yet to apply the ointment just yet) - Also if you forget which pad goes on which side of the rotor, just pick up your old ones you set aside and look at the caliper indention marking and you will know which pad goes where. In Step #5 the caliper should be recessed and you should have enough room to replace the pads.
FRONT PADS- (I apologize for not taking a pic of these steps) Once the caliper housing bracket is back into position (completed in Step #8 ) both front pads ("banana pads") will fit into place just as you took them out. They will fit into metal grove slots on the caliper housing bracket.
REAR PADS - Once the caliper housing is back into position (completed in Step #8 ) both pads ("Square Pads") will slide right into the caliper housing via the picture below:
BEFORE
AFTER
REAR PADS
(ONLY APPLIES TO THE RIGHT-FRONT and RIGHT-REAR BRAKES &#8 211; You will replace the existing Brake wear sensor onto the new pad before you put the pad into the caliper housing bracket)
FRONT:
REAR You will notice that I used the existing pin to hold the disk pad hardware in place. I found that the new pin was longer than the existing pin and would not fit properly. I forgot to take a picture of the difference but I would say the new pin was about 1/4'' longer than the original.
OLD/NEW
REAR You will need to take one extra step on the Right Rear caliper assembly to remove the pin that holds the brake pads and hardware in place. You will need to remove a 8mm bolt that holds the brake wear sensor mount in place. See Pic below:
Step 10 &#8 211; Replace the caliper housing with the 12mm bolts that you have applied thread-locker to and tighten firmly.
Step 11 &#8 211; Replace wheel and lug nuts. Once the vehicle is on the ground, take your 17mm socket and apply it to your torque wrench. Per the owner&#8 217;s manual (I know, of all places to find the recommended torque settings, I found it in the damn manual) set the torque wrench to 80 ft/lbs (53.75 m/kg). Tighten lug nuts.
Step 12 - Start the vehicle and SLOWLY press the brake pedal all the way to the floor and SLOWLY release the brake pedal. Do this a couple of times, then take her out on a test drive! Brakes will feel a little stiff for a few days during normal break-in time.
I hope this simplifies the repair procedure and helps some fellow MB enthusiasts from spending way too much with their local Merc shop. Plus its so much more gratifying when you can fix it yourself. :D
Thanks!
-Toby
1999 SL500, 2004 CLK500, 2006 Cadillac SRX
Nice job and write-up Toby! I did this myself (did not replace rotors on the CLK, but have on other cars). You are correct about the price differential. I'd rather keep the $1,000+ dollars as long as I can physically do this type of labor and I hope to be able to do so for at least another 15 years!
2004 CLK320
Thanks! I'll update this thread tomorrow with more pictures. It took me 2 hours for both sides....im not kidding either. It is simple. Maybe the mods can throw this thread in the CLK Repair/DIY Sticky thread???
Those are the same brakes I put on the C240. I know they are Chinese parts, but I have been very pleased with the performance. For the price, if they only last half as long as OEM or name-brand parts, it's still a heck of a deal.
2004 CLK320
Thread Updated with more pics! Enjoy!
P.S. I know I likely will not get the full use out of these cross-drilled and slotted rotors. The OEM rotors were only $10.00USD cheaper each than the upgraded rotors that I purchased.....For only $40.00 total to upgrade, heck yes I will!
Plus, they look way cooler! My 1979 Porsche 930 had standard drilled rotors - think how radical that was in 1979! They will help stop faster, but you may wear the pads out quicker, but who cares!
2003 CLK 320 Coupe
That's if you consider cross-drilled rotors an upgrade...but that's a whole-nother topic for another day.
w124 400E x R129 w210
Front
So....how did you replace the front and rear pads?
Great write-up but it seems to only show rotors and wear sensors.
Could be me. Thanx
2004 CLK 240 Coupe
Very nice post with excellent photos...
Pads did get a mention from step 9, but there could have been reference to the method of forcing the caliper pistons back far enough to get the new pads in place (they don't just fall in!). And also how to deal with the brake fluid issue here.
2004 CLK320
Could be me. Thanx
Thanks, Updated Step #9...I'll find a pic that I took showing the rear slots in the caliper where you slide the pads in to replace.
Thank you. Check out step #2....updated for Bold Black and Check out Step #5 for Bold Red, updated as well.
2004 CLK320
Discussion Starter #12
Thank you to all for the feedback. This was the first time I've changed the pads/rotors on my CLK. So I do apologize if I left somethings out (which Im sure I did) or missed some photos along the way. I hope this article is easy enough to follow to DIY rotor and pads replacement.
Thanks. :thumbsup:
-Toby
releasing break pads
Hi, thanks for the tutorial. Can you please explain how did you take that square pin out which is holding brakepads in the caliper (in your image IMG_2198-1.jpg). I tried it once but couldn't take the pin out.
Thanks in advance.
2004 CLK320
Discussion Starter #14
Thanks in advance.
You will need a small "punch" and a hammer to punch the pin through. Punch similar to this:
2004 CLK320
Discussion Starter #16
Thanks. One more question, I went to auto part store to get front pads, and the guy told me there are two different sizes, 31mm and 34mm Abutment Clip width. Here on Amazon it says its 31mm for CLK320 2003; which one did you use for ur 2004?
Amazon.com: ATE EU872A Original Disc Brake Pad Set: Automotive
Thanks.
I am unsure of the exact length of the clip.
The Abutment Clips should come in a "disk brake hardware pack" for replacement. Now, I didn't use the new "pin" that came with the pack as it was too long. So I reused the existing pin which was in great shape after a little TLC cleaning.
FYI, when driving out the pin with the drift or "punch" tool, it shouldn't be very hard to do - use gentle, light taps on the hammer. In fact, I can usually remove the pins without a hammer. I press in on the metal clip with one hand, then press the pin out with the drift in my other hand. Of course if there is a lot of brake dust and road grime on the calipers, then it may take a tap or two to loosen it.
CLK 320 Brakes & Rotors
Toby - thanks for the great write up and photos. Without out your help...I'd still be working on the car, or having it towed to the dealership.
One additional note...though I religiously put on the emergency break when I'm change a flat tire, one should NOT put on the emergency break when trying to take off the rotor. The rear rotor ain't gonna come off with the emergency break on. So, after about 1 1/2 hour later, when I decided to release the emergency break (rotor was "springing back in") off comes the rotor. I couldn't help but laugh at my error. Otherwise...all went well. Thanks again.
The Centric rotors and Posi-quiet pads on the C240 are still doing great - money well spent! They do rust when sitting for a day in the rain, but so do my OEM rotors on the CLK500.
1 - 20 of 50 Posts
