My girlfriend has no heat in her 04, c230k. All the fans speeds work. I have heat going to and coming from the heater core and ive checked fuses relating to heat. I let the car idle trying to warm up and felt the ac compressor turning on and off without the ac or defrosters on. I felt the lines going to the evaporator core and they were cold and had condensation on them so I’m stumped. Looking through fuse box diagrams stand I can’t seem to find a ac clutch relay on any of them. If anyone’s had an issue like this before let me know. Also the heater core is not by passed
Few things to check;
Faulty or old coolant temperature sensor. About 15-20 bucks from the dealership. Not sure if they raised the price.
Wrong antifreeze(use Mercedes/or European specific.. usually a blue color). I had no idea how this made a difference until I was informed by a tech. If not currently using Mercedes specific coolant, flush the system with new approved coolant. Burp the system.
Ensure that there is no issues/ sticking from the thermostat. They tend to go bad after 100,000 miles and the housing/gasket is prone to causing leaks.
Ensure high and low pressure a/c ports aren't leaking from the valve stem.
Hope this may help
